Author Topic: New speedometer cable bouncing.  (Read 4947 times)
Offline boyer61
« on: October 27, 2011, 09:50:12 pm »
Hey guys, i just replaced my speedo cable cause of a noise.
The problem im having is, from 0-35 MPH the needle bounces up and down 5-7 MPH until it reaches exactly 35 MPH then it's smooth.
I tried to make all the bends on the cable as smooth as possible, what could be the issue?
Offline PromiseKeeper
Re: New speedometer cable bouncing.
« Reply #1 on: October 28, 2011, 07:21:29 am »
when an old one does that, graphite helps....were you supposed to lube it before install?
Offline boyer61
« Reply #2 on: October 28, 2011, 09:24:40 am »
I assumed no, so i didnt lol. I'll pull it off again and ill see it that fixes it.
Offline boyer61
« Reply #3 on: October 28, 2011, 12:39:49 pm »
I lubed it up with some graphite at both ends. still doing the same thing. No sharp turns at all on the cable, the old one didnt do this lol
Offline Grim 82
« Reply #4 on: October 28, 2011, 02:19:38 pm »
I've had that intermittently after messing around in the dash, or when it's really cold out. Make sure that the cable is fully seated and retained onto the back of the gauge, and that the square hole socket in the gauge isn't rounded out.
« Reply #5 on: October 28, 2011, 03:51:29 pm »
you have to lube the WHOLE cable inside the sleeve....
Offline boyer61
« Reply #6 on: October 28, 2011, 11:08:30 pm »
I dumped a good bit of graphite in the tube and wiggled it around the best i could to work it down.
I'll probably take it out again and grab another one tomorrow while i'm at work. Home fully it's just defective.
Offline boyer61
« Reply #7 on: October 28, 2011, 11:15:06 pm »
Ahh crap. come to think of it, i did accidently bend the cable when i installed it, about 60-70 degrees. looks straight but i guess the inside isn't
Offline boyer61
« Reply #8 on: October 29, 2011, 05:37:44 pm »
New cable works like a charm!
