Author Topic: How to tell if you have a 305 or 350.  (Read 22371 times)
Offline boyer61
« on: October 29, 2011, 05:42:35 pm »
I know there are casting numbers on the rear of the drivers side on the block. What the easiest way to see it? I tried from the top, I took some pictures near the oil pressure switch area, doesnt look anything like casting numbers, where are they exactly?
Re: How to tell if you have a 305 or 350.
« Reply #1 on: October 29, 2011, 05:48:20 pm »
Offline boyer61
« Reply #2 on: October 29, 2011, 05:57:28 pm »
If im reading this right the #s are on the front of the passengers  side??
« Last Edit: October 29, 2011, 05:59:43 pm by boyer61 »
« Reply #3 on: October 29, 2011, 06:06:33 pm »
The casting numbers are on back but the numbers that should give you the most info is behind the alternator on the engine block pad.  Look through and it should tell you exactly what your engine came from.
Offline boyer61
« Reply #4 on: October 29, 2011, 06:07:41 pm »
I only seen 1 set of #s 1222CPY
« Reply #5 on: October 29, 2011, 06:10:06 pm »
CPY    1977   305    LG3    U    145    2    F A X
Looks like it's a 1977 305
Offline boyer61
« Reply #6 on: October 29, 2011, 06:14:09 pm »
Just seen that. Guy i bought it from said it was an 85..  What does FAX mean or stand for?
« Reply #7 on: October 29, 2011, 06:19:52 pm »
It could have come in a Camaro, Nova or Chevelle in 1977
Offline Jeffroe2114
« Reply #8 on: August 13, 2013, 11:58:25 am »
The # I pulled from behind the alternator was 171470020 K03 CRA.
« Reply #9 on: August 13, 2013, 03:59:56 pm »
CRA    1977   305    LG3    U    145    2
Offline fischebc
« Reply #10 on: September 09, 2013, 02:24:08 am »
I'm having the same issue trying to figure out what's in my 85 Chevy Silverado 4X4. The numbers on the casting are V0526CHS?
« Reply #11 on: September 09, 2013, 06:27:39 am »
CHS    1978   350 auto trans. LM1   L    170    4    Camaro
Offline fischebc
« Reply #12 on: September 09, 2013, 01:30:03 pm »
Thank you sir, just wanted to verify that I was looking at the right plate. The one behind the alternator? There is another set of numbers but no letters on this one 16J308637?
