Author Topic: chevy 4-speed  (Read 26126 times)
Offline scottsdale92
chevy 4-speed
« on: November 03, 2011, 12:16:48 am »
ok  mule-gear 4-speed has no fuel milage,wanting to swap to the a883 overdrive which is common in chevy trucks 82-86 will an np208 t-case bolt to it and will my bell housing work?? and also driveshfts?? need some info
1984 chevy scottsdale LB 4x4
Re: chevy 4-speed
« Reply #1 on: November 03, 2011, 07:06:07 am »
     Actually I am receiving my A833/OD and 208 transfer case this monday. (out of a 84 k10 chevy)  From my research, you need the bell housing that is on the A833, which will bolt to the 350, the one on the SM465 will not bolt to the A833.
     The 208 came with the OD transmission.  I am not sure on the driveshaft length, but when I receive them I can find out.
     I have to point out 1 comment you made.  They were not as"common" as you might think, or there are just not that many out there left.  I have been looking for almost a year before finding this set.  I did find at least 2 places on the internet that sell them, but they were pricey by the time you buy bell housing, parts for clutch, etc. etc.  I have found several 2wd versions at local pick-n-pull places around my house, just not 4wd versions.
     Another point, they are not as strong as the SM4645, but in my case, my truck will only see fire roads and camping, otherwise it will be a street truck, so the OD will put me in the perfect rpm range with my tire size I want.
     Hope this helps, any more questions, ask, I have a lot of research I have done.
Online zieg85
Re: chevy 4-speed
« Reply #2 on: November 03, 2011, 08:24:26 am »
Most of the bell housings on the 82 on up I have seen have the dual bolt pattern to accept either transmission.  They are a rare find even in 2 wheel drive.  The biggest/hardest component is the shifter and linkage.  If you find that you've scored big time.  Even though it is a Hurst shifter and Hurst will rebuild they do not list them for sale.
Re: chevy 4-speed
« Reply #3 on: November 05, 2011, 04:22:46 pm »
ok cool i could have me driveshft re-worked,my truck is a longbed 4x4 i dont do heavy pulling but i do go wheelin on occasion.  would the trans handle 33x10.50's?
Offline Engineer
Re: chevy 4-speed
« Reply #4 on: November 05, 2011, 10:32:45 pm »
If you are looking at an O/D tranny look into the NVG4500. It is essentially the SM465 only with an O/D gear. Plus there is a ton of aftermarket support for it.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Re: chevy 4-speed
« Reply #5 on: November 05, 2011, 11:47:27 pm »
     Nv 4500 will require modifications, the a833 is basically a plug and play swap.
Re: chevy 4-speed
« Reply #6 on: November 07, 2011, 05:15:32 am »
with the nv4500 id have to do alot of modifications espically with my t-case.i have looked into that,and what clutch set up does the a833 have to have mech. or hydro.?
Re: chevy 4-speed
« Reply #7 on: November 07, 2011, 07:04:02 am »
     On your 84, if you could find the sep up out of an 81 - 84 chevy that had the a833, you just need to swap it over.  I wish you better luck than I had, it took me almost a whole year to find mine, (i did get mine on friday, which had the cross member and clutch parts, so I was surprised).  Here's some pics of mine.
Re: chevy 4-speed
« Reply #8 on: November 07, 2011, 09:38:56 pm »
thats freakin sweet,could you help me out with some connenctions?
Online zieg85
Re: chevy 4-speed
« Reply #9 on: November 07, 2011, 09:49:01 pm »
Bake, less than a year is good... It took me 18 months and a 1100 mile round trip for my first one.  Second one came in a truck I bought off of eBay, stumbled across a third at a swap meet...
Re: chevy 4-speed
« Reply #10 on: November 08, 2011, 12:21:52 pm »
     Do you mean connections on where to find one ?  If so that is why it took me almost a year to find one.
Offline Da67goatman
  • Burban
Re: chevy 4-speed
« Reply #11 on: November 08, 2011, 06:37:38 pm »
Kinda on topic, can I use a mopar 833 and the chevy bellhousing or the mopar bellhousing and an adapter plate?  There are way more mopar 833 out there than GM.
<Pitcrew>
Online zieg85
Re: chevy 4-speed
« Reply #12 on: November 08, 2011, 06:41:24 pm »
Input shaft is different, longer to.  They are out there you just gotta be searching for them and know what you are looking for.  Just like when I found one at a swap meet, trans with linkage no bell housing.
http://www.ebay.com/itm/chevy-4x4-hydraulic-bellhousing-pickup-truck-a833-3-4-5-speed-swap-t10-muncie-np-/260885784131?hash=item3cbe012643&item=260885784131&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
Is for a 85 on up juice clutch with the dual pattern, SM 465 and the A 833
« Last Edit: November 08, 2011, 06:46:38 pm by zieg85 »
Re: chevy 4-speed
« Reply #13 on: November 09, 2011, 05:35:36 pm »
     Zeig is right, mopar will not mate to chevy as far as the 833, and again zeig is right, the chrysler a833's, especially the 2wd ones, can be found on 3 speed cars also (colum shift also).  They put that trans into 3, 4, and 4(O/D) versions from the 60"s up the mid 80's.
Re: chevy 4-speed
« Reply #14 on: November 09, 2011, 06:45:28 pm »
yea like where could i start looking for one
