Interior & Equipment
Wiring Cab Roof Lights to Headlight Switch
Topic: Wiring Cab Roof Lights to Headlight Switch (Read 8581 times)
LTZ C20
November 03, 2011, 07:34:57 pm »
Ok so I need some help on the headlight switch. When they arrive, I will be installing new cab roof lights. My truck does not currently have them. The package is suppose to included a wiring harness and switch for separate operation from the head lights. I want them to work with the headlights, so would I be able to get a wiring harness plug from an old truck with roof lights and just splice the plug onto the new wiring and plug it into the headlight switch? I not sure if all headlight switches are the same either, do they have a spot on the back side for a cab roof light harness? Thanks y'all.
LTZ Cheyenne C20
bake74
Re: Wiring Cab Roof Lights to Headlight Switch
November 03, 2011, 10:05:26 pm »
That sounds right, but I would include a relay circuit so I was not pulling power away from your headlights.
74 k10, 77k10 Tom
Jason S
November 03, 2011, 10:11:48 pm »
The original setup would've had the roof lamps coming on with the parking lamps (first pull of the headlight switch). They would then stay on when the headlamps came on, as would the rest of the marker lamps.
Last Edit: November 03, 2011, 10:18:19 pm by Jason S
November 03, 2011, 11:42:41 pm »
Ditto on what Jason stated, and the harness would tie into the existing harness.
LTZ C20
November 04, 2011, 12:16:15 am »
Excellent! That's what I was hoping for. The idea for relay circuit is good too. Thanks y'all, that really makes things a lot easier when I put them things in.
LTZ Cheyenne C20
DustyRusty
November 08, 2011, 07:54:12 pm »
If you're going to add a relay just for your cab roof lights, you might as well add two more relays. One for your high beam headlights and one for your low beams. You will have much better visibility and reduce the load on your headlight switch. My $.02.
Rusty
1975 K-10 SWB Fleetside - 350/SM465/NP205/D44F 12-boltR, 3.73 gears. Original owner.
Customized by rust.
LTZ C20
November 09, 2011, 06:27:11 pm »
Thanks Rusty. I will definitely look into that, it sounds like a good idea too. I think those lights should be here next week.
LTZ Cheyenne C20
