Author Topic: np 203 shifter  (Read 8867 times)
Offline wvuredneck09
np 203 shifter
« on: November 06, 2011, 07:52:40 pm »
Just bought a 79 GMC K1500 with a NP 203.  However the previous owner has put a different boot/handle/knob combo on it that is really bad IMO.  I am interested in getting a stock replacement, any ideas on were to look or does anyone have one laying around?  I also may be purchasing a  4spd manual transmission for the truck with a 205 transfer case (I love manual trans.)  what all would be involved in the changeover?
79 GMC K-10 work in progress
Re: np 203 shifter
« Reply #1 on: November 06, 2011, 09:16:34 pm »
junkyard for the handle, and you need from the clutch pedal to the driveshafts. if you do some searching on here i think its covered
Re: np 203 shifter
« Reply #2 on: November 07, 2011, 07:09:00 am »
     Irish is right about the handle.  And as for as the swap, I have found a donor truck is the easiest way to go.  Unless you have like a pick-pull where you can go and pull all the parts you need.  Trying to piece together everything takes along time and can get costly.
Re: np 203 shifter
« Reply #3 on: November 07, 2011, 10:32:41 am »
Might have found a donor truck.
« Last Edit: November 07, 2011, 12:13:59 pm by Captkaos »
Offline jdl71
Re: np 203 shifter
« Reply #4 on: November 07, 2011, 07:06:35 pm »
coloradok5 has a pretty good write up on this swap
Re: np 203 shifter
« Reply #5 on: November 09, 2011, 07:14:44 pm »
Thanks for the link, might be a little more than I'm willing to get into at the moment.
Offline Engineer
Re: np 203 shifter
« Reply #6 on: November 11, 2011, 04:47:18 pm »
Auto to 4-sp.....It is really not that bad. I have done it numerous times.
The holes in the frame for the x-member even line up right on the money when switching from a TH-350/NP203 to the SM465/NP205. :)
The first time I did it I had the two trucks side x side. Now I can do it in my sleep.
« Last Edit: November 11, 2011, 04:49:17 pm by Engineer »
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Re: np 203 shifter
« Reply #7 on: November 11, 2011, 08:45:49 pm »
well then by all means come to WV and teach me lol.  Its to nice of a truck for me to take the chance on screwin up.
Offline thirsty
    • Suitor's Garage
Re: np 203 shifter
« Reply #8 on: November 12, 2011, 03:09:11 pm »
Sleep apnea?
Offline Engineer
Re: np 203 shifter
« Reply #9 on: November 12, 2011, 06:22:56 pm »
Sleep apnea?
Nope, just dreamin about Chevy trucks. :)
