Author Topic: Gas gauge issues  (Read 6193 times)
Offline mlintner71@yahoo.com
Gas gauge issues
« on: November 10, 2011, 10:48:39 pm »
I'm new here and hopefully can get some answers! I have an 85 k-10. My problem is my gas gauge works fine on the pass side tank, but not on the driver side tank, I put new tanks, and sending units in both. I put  a new switching solenoid on and a new tank switch in the dash. The driver side goes way past full. Can you help?
Re: Gas gauge issues
« Reply #1 on: November 10, 2011, 11:02:44 pm »
Welcome to the site from NW Indiana.  "Usually" a way past full indicates a bad ground on the tank that is giving you fits.
« Reply #2 on: November 10, 2011, 11:20:21 pm »
We checked and rechecked ground. Cleaned and re attached the ground to no avail. Is it possible the gauge could be messed up and only tread one side? Or am I looking at wiring issue? Thanks
« Reply #3 on: November 10, 2011, 11:28:23 pm »
If the gauge works on the other tank you must have a wiring issue then.  Wish I could help more.
« Reply #4 on: November 10, 2011, 11:37:41 pm »
That's what I'm afraid of lol. Thank you for your input it's greatly appreciated.
« Reply #5 on: November 11, 2011, 12:10:22 am »
      Welcome from California,  one way to determine if it is electrical or mechanical.  Switch sending units around and see if it is still drivers side or now the passenger side is affected.  If it switches to passenger side, it is problem with sending unit.
« Reply #6 on: November 11, 2011, 12:49:12 am »
Ugh that sounds like no fun at all lol! Before I put new sending units in it did the same thing. I'm just hoping I can maybe get lucky and it be the gauge. But I think I'm gonna be checking wiring.
« Reply #7 on: November 11, 2011, 08:18:40 am »
     Well that changes a few things, if it did it with the old sending units too, I would say it is not the gauge, otherwise it would do it with both tanks.  Next is to check your grounds again like zieg said.
     Was it the same side before that did it ?  If so it would have to be a wiring issue.
« Reply #8 on: November 11, 2011, 11:59:40 am »
Have you looked at the posts in the Tech section regarding these?
