Author Topic: Edelbrock performer carb - vaccum lines  (Read 3939 times)
Offline Elpresidente
« on: November 12, 2011, 09:08:43 am »
So Ive got myself an Edelbrock 600 performer carb, and it has 3 vaccum lines on the front -  a ported and unported vaccum line, and a larger one in the center that im not sure of.
Which lines on the vaccum canister in the truck would be ported/unported? and where would the center connect to?
'82 Chev Scottsdale
Proud to be Canadian \m/
Offline jaredts
Re: Edelbrock performer carb - vaccum lines
« Reply #1 on: November 12, 2011, 09:58:09 pm »
Ported to vacuum advance on the distributor if you want to stay like stock, non-ported (manifold vacuum) if you want a little more performance curve from your advance.  You can do some searching on that and get up to speed.  The big one on the bottom to pcv valve.
