Author Topic: 1983 bench seat replacement  (Read 25525 times)
Offline powerT
« on: November 13, 2011, 12:13:53 pm »
Is there any other years that the bench seat will fit in an 83
Re: 1983 bench seat replacement
« Reply #1 on: November 13, 2011, 12:34:55 pm »
1981-1987 on up to 1991 rear seats in crew cabs if you want a direct bolt in.  They physically bolt in down to 1973 however the seat belts need to go through the seat bottom to be right and the 3 point system is different on the older ones.  Crew cab and Suburban front seats also work but don't tilt forward to access behind the seat and the seat sliders either have to be bent in the rear or use your 1983 ones as the floor contour is different where the rear sliders mount.  That is the easiest replacement.  All others will require custom mounts.
Offline mattgood
« Reply #2 on: November 23, 2011, 10:18:24 pm »
zieg85 pretty much summed it up. I know 88-94 seats are the same size but not a direct bolt in.
Don't let your water melon.
Offline 1980c10
« Reply #3 on: November 24, 2011, 07:30:16 am »
I used my old brackets on my 88-94 seat just had to drill two holes in the seat frame. So they are pretty close to a direct fit and a nicer overall fit to the truck as the seat sits lower and has a thinner back for more room.
Offline 69byrd
  • Haulin!
« Reply #4 on: November 24, 2011, 10:11:55 am »
I had the 88 and up seat in my truck and replaced it with a seat from a 83. I found that the new seat was to narrow and was not as comfortable. But it is really a personal preference as to which seat you want.
Offline powerT
« Reply #5 on: November 25, 2011, 10:55:22 pm »
Thanks I may end up redoing the old one
Offline mattgood
« Reply #6 on: November 26, 2011, 10:20:57 pm »
I didn't realize it was that easy to swap. Yeah I think the 88-94 is more comfortable for sure.
