Engine/Drivetrain
galley plug question
Topic: galley plug question (Read 3117 times)
jdl71
November 19, 2011, 01:49:58 pm »
Should all three holes in this pic have a plug? They are all threaded, and since I didn't remove them I don't know where they all were.
bake74
Re: galley plug question
November 19, 2011, 02:30:44 pm »
The one above the oil filter should, the other two looks like they had brackets with bolts going to them. Have you looked to see if they are all the way through the block ? I believe the one is a plug and the other two have bolts. Someone will confirm or correct me if wrong.
74 k10, 77k10 Tom
jdl71
November 19, 2011, 02:52:45 pm »
Thanks. Think I figured it out, pretty much just what you said. The other 2 are blind holes, the one above the oil filter I plugged. Seems like when you buy a plug "kit" it would have the right amount of everything you need but that is not the case.
Engine/Drivetrain
