Author Topic: Brake Problem  (Read 5550 times)
Offline Sodium Duck
Brake Problem
« on: November 19, 2011, 05:09:52 pm »
My brake pedal slowly glides down. It feels firm and normal to a point, but if you keep your foot on it, it slowly keeps going down. It doesn't hit the floor, but it's dang close.
Replaced master cylinder. (Also had the front axle apart recently, so I did new pads and rotors and bushings for the front). Bled all 4 brakes. Checked rear drums and found they were loose. Adjusted them up somewhat snug to the drum. Still does the same thing.
When I push the brake pedal I can hear a whooshing air noise, but the pedal catches almost instantly and I can not hear a vacuum leak. Also, I feel like I have to pump the pedal once or twice to get the brakes up high. Otherwise the brake pedal is really low.
Do I just have air in my lines or something? The pedal doesn't feel spongy...    ???
1985 K10, corporate 10-Bolts front and rear, 6" lift, 35's, 305, auto, longbed.
Re: Brake Problem
« Reply #1 on: November 19, 2011, 05:22:19 pm »
Sounds like there is still some air in it by what you describe.  You also could have a bad replacement master cylinder... Been there....
« Last Edit: November 19, 2011, 05:23:54 pm by zieg85 »
Offline mattgood
Re: Brake Problem
« Reply #2 on: November 22, 2011, 09:37:46 pm »
I would first bleed the brakes again to make sure no air is in the system. Also a sinking pedal could mean you have a leak, so check your calipers, wheel cylinders, lines and bleeder screws. I agree that it could also be a faulty master, although I have yet to see that.  Hope you get it figured out.
Don't let your water melon.
Offline sbx22
  • 1974 1/2 ton 350 sbc
Re: Brake Problem
« Reply #3 on: November 26, 2011, 09:14:49 pm »
Try bench bleeding if you have messed with the master brake cylinder. Matter of fact, I just did this to mine and it works wonders now. And it's easy enough, it's worth a try.
