Author Topic: 700r4 to th350??  (Read 4019 times)
Offline 86silverado
700r4 to th350??
« on: November 20, 2011, 04:02:19 pm »
I have an 84 chevy half ton 2wd. has a 305 and a 700r4 right now.  we just put a 355 together for it and tranny in it now is slippin. i have a th350 that was just rebuilt, tailshaft is 9 1/4.,    I was wondering what ill need to change to make it work.  Will driveshaft and shift linkage work?
Re: 700r4 to th350??
« Reply #1 on: November 20, 2011, 04:09:23 pm »
check the lengths of each transmission.  I know the short tail shaft TH 350 will replace the 3 speed "three on the tree" trans with no modifications.  The long tail shaft TH 350 works for the 700R4, same yolks.
Offline 86silverado
« Reply #2 on: November 20, 2011, 04:12:38 pm »
so the 9 1/4 would be the long tailshaft?   and would shift linkages, lines etc need changed?  Someone was saying speedo wouldnt work right. both are cable though,  gear inside retainer might be diff
« Reply #3 on: November 20, 2011, 04:27:30 pm »
I don't know the lengths of the tail shafts but everything else should work fine.  I am going from a TH350 to a 700R4 week after next in my 85 C10.
