Author Topic: 76 4x4 engine support and motor mounts used on 81 2wd frame  (Read 5177 times)
Offline ToreyC
« on: November 22, 2011, 08:11:45 pm »
I'm converting my 81 long bed 2wd truck to 4wd. i'm using a 76 4wd long bed truck for parts and as a refrence point. Right now, i have the front end out from under the 2wd truck. I have pulled the cross member and engine mounts off of the 4wd. What i'm wondering is if the cross member and engine mount from the 4wd will work on my 2wd? If so, will i have to do any modifications and what would that consist of? I was also wondering if anybody had some kind of blue print of my frame that would show exactly where everything would bolt up. Any help on this topic would be greatly appreciated. Thanks in advance.
81 LWB 2WD converting to 4WD Chevy
85 SWB 2WD Chevy
2011 Chevy Suburban 4WD
2003 Chevy Express Van (Work Truck)
Without The Risk There Is No Reward
Offline thirsty
    • Suitor's Garage
Re: 76 4x4 engine support and motor mounts used on 81 2wd frame
« Reply #1 on: November 22, 2011, 08:44:01 pm »
That should work with no modifications except for drilling the frame.
This is the only picture I could find of that area. Sorry it is so small.
Offline thirsty
    • Suitor's Garage
« Reply #2 on: November 22, 2011, 09:05:17 pm »
I found this too. I was making a jig for that same thing here. I used the holes for the spring shackle, the ground clamp is clamped to one of the jig bolts.
Here I had it off and was just making sure it was welded good I guess.
