Author Topic: Help! 84 K10 heat selector vacuum source question  (Read 5202 times)
Offline Lmbull
« on: November 25, 2011, 01:01:03 am »
I just picked a '84 K10 short bed that's needs some TLC.  I have heat through the vents on the front of the dash whether the selector is set to "off" or another setting. I'd swear I read somewhere that the vacuum source for the heat selector came from somewhere on the AC. The truck had AC but it was removed. I would very much appreciate any help that could be provided. I live in Ohio so defrost is an absolute must.
1984 K10 SB 350 th350 converted NP203 and 3" body lift
Re: Help! 84 K10 heat selector vacuum source question
« Reply #1 on: November 25, 2011, 10:27:33 am »
     Did you check to make sure the selector switch is actually moving the flap between forward and defrost ?
Offline Lmbull
« Reply #2 on: November 27, 2011, 08:12:22 pm »
The problem was a cracked hard plastic vacuum line that connected to a T from the reservoir.
Sent from my DROIDX using Tapatalk
« Reply #3 on: November 27, 2011, 11:23:55 pm »
     Cool, at least you now got it fixed or shortly will.
