Author Topic: Bad front caliper?  (Read 5902 times)
Offline Elpresidente
Bad front caliper?
« on: November 27, 2011, 05:15:18 pm »
I put 2 new front calipers on my '82 C10. The drivers side bleeds just find, but when I went to crack the bleeder screw on the passenger side - nothing. even with the bleeder screw loose and someone stomping on the brakes, not a drop came out. I pulled the banjo fitting, and there was definitely pressure in the line up to the caliper.
Do I just have a bad caliper or am I missing something?
'82 Chev Scottsdale
Proud to be Canadian \m/
Offline 1978 454 Big 10
  • Don't Mess With Texas! :)
Re: Bad front caliper?
« Reply #1 on: November 27, 2011, 05:19:52 pm »
If you have fluid/pressure at the end of the hose, must be the caliper.
If these are new/rebuilt calipers, you did remove the plastic plugs right?
« Last Edit: November 27, 2011, 05:28:25 pm by 1978 454 Big 10 »
1978 Chevy C-10 Silverado "Big 10" 454, 400 turbo, PW, PDL, Tilt, Cruise, AM/FM, Factory Tach, Dual Tanks, Locking Diff, Sliding Rear Window, Trans Cooler, Cordova Brown/Santa Fe Tan. 052,600 Original miles!
« Reply #2 on: November 27, 2011, 11:25:42 pm »
Yes. the plastic plugs are out, might be something in the bleeder screw; will check tomorrow
'82 Chev Scottsdale
« Reply #3 on: November 27, 2011, 11:27:49 pm »
Had to ask! :)
« Reply #4 on: November 27, 2011, 11:44:26 pm »
     My favorite quote is always the same "The easiest and most obvious solution to any problem is 99% of the time correct."
