Author Topic: A/C continues to run with "Vent" selected  (Read 3164 times)
Offline Edahall
« on: November 28, 2011, 02:30:40 pm »
Vehicle: 1990 Suburban
Several days ago as I was driving, I noticed that very cold air was coming out of the vents even with "vent" selected on the controls. I started investigating and the A/C compressor is now stuck on with "vent".   However, the A/C compressor does disengage when "heat" is selected on the controls.
How can I fix this problem?
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
Offline DrDaryl
Re: A/C continues to run with "Vent" selected
« Reply #1 on: November 28, 2011, 04:11:59 pm »
On mine it was the "AC actuator switch" located on the climate control unit--had a hole burned through it and the compressor ran all the time--might help.
Offline Edahall
« Reply #2 on: November 28, 2011, 06:34:19 pm »
Thanks,  I bet this switch is the culprit on mine as well.  Maybe it's out of adjustment or needs cleaning.
-3.73 gears
-2" Lift
Offline Project86
« Reply #3 on: November 29, 2011, 09:57:45 pm »
I also had this and found a hole burned through the actuator switch. Replaced it with a new one from Auto Zone, problem solved!
86 Silverado C10 S/B
