Author Topic: Older cabs fitting  (Read 5301 times)
Offline bowdown916
Older cabs fitting
« on: December 04, 2011, 12:05:24 am »
Sup guys. Was wondering what cabs years will fit on a 1980 frame..
Sent from my DROIDX using Tapatalk
Re: Older cabs fitting
« Reply #1 on: December 04, 2011, 12:10:59 am »
     73 - 80 for sure, the frames are the same up to 87, I do not know if 81 - 87 cabs will work though, some one will chime in.
« Reply #2 on: December 04, 2011, 12:38:59 am »
73-87 cabs will fit, up to 91 1 tons cabs will fit all 73-to 87 frames. You need to use the cab mounts that match the years of the frame though. 73-80, and 81-87/91
Offline bowdown916
« Reply #3 on: December 04, 2011, 10:33:59 pm »
Umm.ok. I bough a c10 81 for parts me n my bro needed. And I was wondering if I could use that frame with a 1970 c10 cab..
« Reply #4 on: December 04, 2011, 11:43:57 pm »
     I do not believe so, I believe the 70 cab mounts are different, though I guess with modifications it will work.  It just wont bolt right on.
« Reply #5 on: December 06, 2011, 08:25:06 pm »
Cab mounts from 1960 to 1972 are the same spacing, core support mounts are different. But none of those cabs are a direct swap onto a 73 or newer frame.
