Author Topic: Headlights Won't Turn on  (Read 35255 times)
Offline 1984k10
« on: December 05, 2011, 07:52:24 pm »
My headlights used to only come on with the highbeam on. I've replaced the dimmer switch but they still won't turn on. The highbeam indicator no longer comes on either. I'm getting zero power to the headlights per volt meter.  I've looked at the wiring diagrams and can't seem to figure out where the bad connection is.
On a 1984 K10 do they have a relay? I don't think it's an issue with a fuse since I can't seem to find one for headlights.
Re: Headlights Won't Turn on
« Reply #1 on: December 05, 2011, 08:21:59 pm »
Fuse links protect battery feeds into the cab.  The headlamp switch houses a non-serviceable circuit breaker for the headlights.  The running lights are fused separately through the fuse block.  Check for burned fuse links coming off the battery cable stud at the starter as well as at the junction block double stud mounted to the firewall right of the brake master cylinder.  If fuse links are OK check the red feed wire to the headlamp switch (should be battery).  Use the wiring diagrams to work your way down circuit to the dimmer switch and headlamps.
Offline 1984k10
« Reply #2 on: December 05, 2011, 08:26:03 pm »
The headlights connect to the starter you say? Where did I put that flashlight....
Offline bigchevyc30
  • the pig
« Reply #3 on: December 05, 2011, 09:10:48 pm »
you might have the same issue i hadd i had the wire that connects to the altnator and starter get burned in half from hitting my headers maybe yours is the same thing
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
« Reply #4 on: December 06, 2011, 01:00:12 am »
what about the headlight switch?
« Reply #5 on: December 06, 2011, 04:30:42 am »
     The fuse able link he mentioned is off the starter through the double studded connector block on the firewall, this is where you get power for the circuit.  A lot of times the fuse able link goes bad and is not serviceable, there is a write up in the tech section on how to make a new fuse able link.
