Author Topic: mpg  (Read 49465 times)
Offline 84chvy
mpg
« on: December 06, 2011, 12:54:10 pm »
hey guys i was just wondering what everyone got on mpgs. give me your setup and mpg. ex. motor/trans/rear end gears/tire size/tire type/engine mods.
Offline 1979C20
  • Kyle Taulton.
Re: mpg
« Reply #1 on: December 06, 2011, 01:04:10 pm »
Rebuilt 350 with a hearty cam. SM465 trans, 4.10s, 33x12x16(285/75r16) BFG All Terrains. Last time I checked im getting 8-10, but that was when I had 31's. Id guess 12-13 now since I had a tune up and the bigger tires.
« Last Edit: December 06, 2011, 01:45:25 pm by 1979C20 »
Offline 84chvy
Re: mpg
« Reply #2 on: December 06, 2011, 01:04:44 pm »
thats not good.
Offline black85k10
Re: mpg
« Reply #3 on: December 06, 2011, 01:35:45 pm »
GM performance 350 with 330 hp th400 trans stock gears 31x10.50-15 general grabbers at2 tires. the last time i checked i was getting around 12 mpg
85 chevy k-10 350 th400
Offline mrboyy17
Re: mpg
« Reply #4 on: December 06, 2011, 01:47:36 pm »
86 4x4 scottsdale 3/4 ton 6.2diesel stock tires, and everything stock
18mpg
Re: mpg
« Reply #5 on: December 06, 2011, 02:52:42 pm »
1985 C10 305 TH350 2.73 P205/75/15  15.6 mpg
1985 C20 454 4 speed 3.21 gears LT235/85/16 load range E 15 mpg
1985 C30 350 TH400 4.56 gears LT265/70/17 load range E 12 mpg
All taken mixed Highway/rural and all trucks have over 100K on stock engines with stock quadrajets
« Last Edit: December 06, 2011, 04:27:29 pm by zieg85 »
Offline 84chvy
Re: mpg
« Reply #6 on: December 06, 2011, 03:58:54 pm »
thank you for all the replies.
Offline 1MCP7.3/87GMC
  • 75s my baby
Re: mpg
« Reply #7 on: December 06, 2011, 11:51:06 pm »
Sad part is I should be getting better then what I get. 1975 Chevy 350 tbi stock out of an 87 gmc 700r4 trans 3:73s pushin 33" savero m/t half town half freeway 13.1mpg that's the best I've ever got. My 84 2wd with a 290hp crate 350 with true duel exhaust flow tech headers running a 600cfm Edelbrock 700r4 and I believe 2.08 rear gears got around 7-8mpg but when I pulled that motor and put it in my 62 impala with a 3 speed on the column and unknown rear gears gets around 17mpg with factory exhaust manifolds and a offenhouser intake and Holley 570cfm carb. Not to mention the impala tachs around 1200 more rpms at freeway speeds then my 84 did.
1984 Chevy Silverado 2wd swb (311hp 350) El Diablo Rojo
1975 Chevy Scottsdale 4wd swb  silver slug 350 tbi
1987 GMC Sierra 4wd lwb 350 stock replacement
Offline str8bloc
  • MISTRESS
Re: mpg
« Reply #8 on: December 08, 2011, 08:30:31 am »
1986 lwb 305 700r4 2.73 peg leg. i get 13 mpg even with a leaky carb  and esc dist.
FaTbOy
Offline ehjorten
Re: mpg
« Reply #9 on: December 08, 2011, 10:49:13 am »
I get a little over 11 MPG in my '91 V3500 with the TBI454 and 4L80e with 4.10:1 rear gears on 35's with 8" of lift.  Now that was a mouthful! :D
-Erik-
Offline bluecrew
Re: mpg
« Reply #10 on: July 04, 2012, 06:05:32 pm »
yeah, I'm digging up old threads.
Tell me if I'm crazy, but I bought my 91 V3500 300 miles away from me, and the whole way back, mostly interstate (~70-75mph) I scored 20 mpg.  Small block 350, 4L80E, stock everything.  Checked the math three times, still came out to 20.  Sounds insane, right?
Offline fitz
Re: mpg
« Reply #11 on: July 04, 2012, 10:19:27 pm »
Bluecrew,i agree. 20 mpg's from your set up does sound insane.
Trust me, I don't question your math, just  keep in mind when people change gears and tires the odometer does not read accurately.
« Last Edit: July 04, 2012, 10:21:19 pm by fitz »
Offline jaredts
Re: mpg
« Reply #12 on: July 04, 2012, 10:22:35 pm »
I hate to say it, but there's no way you're getting 20.
Offline howlinwolf
Re: mpg
« Reply #13 on: July 05, 2012, 09:19:34 am »
speedo is off possibly. i can only make a rough estimate of maybe ten. 350, quadrajet, 425 propane carb, 3.23 gears possibly, 4wd with stock tires, a heavy ass flat bed, and 80 gallon fuel tank on the back
78 Chevy Custom Deluxe flatbed, PROPANE POWERED
Offline slammed79
  • Thou shalt not drive stock
Re: mpg
« Reply #14 on: July 05, 2012, 09:36:23 am »
I get 14.5 or so mixed driving, 255/60/15 3.73 rear, sm465, fresh tune up and rebuilt qjet all on a 350. That factors in how heavy my foot feels on any given day too.
Praise the lowered
