Author Topic: Question about engine replacement  (Read 10077 times)
Offline got2haul
« on: December 08, 2011, 08:56:47 am »
I’m in the planning stage for a future purchase to replace my truck’s engine.  Eventually I intend to replace the transmission as well with a Richmond T10 4 speed, but initially I’ll need to buy and install a new motor first.
Given my configuration: 2 wheel drive, SM465 4 speed, 3.08 rear axle ratio, is the GM Performance Parts standard ZZ4 crate engine too much power (355 HP, 405 lb/ft torque)?
1980 Custom Deluxe Stepside
        Stepside thread: http://forum.73-87chevytrucks.com/smforum/index.php?topic=7505.0
1976 GMC Sierra Grande C15
Re: Question about engine replacement
« Reply #1 on: December 08, 2011, 10:13:44 am »
     For that sm 465, that engine is not to much.  A lot of people on here are going to tell you to put a 2000 or newer 350 in, the advancements way out weigh the older engines.
     If you plan on installing a new engine/trans combo, why not go with a 5 speed transmission ?
Offline got2haul
« Reply #2 on: December 08, 2011, 10:56:55 am »
I know this is going to sound like a dumb reason for wanting a 4-speed over a 5-speed, but here it is…
When I’m driving, I like to keep my right hand on the shift knob.  With a 4-speed, while in 4th gear, the shifter is in a position close to the seat, making it very comfortable to rest my hand on the shifter.  With a 5-speed, 5th gear is close to the dashboard, causing me to have to stretch my arm out to be able to keep my hand on the shifter knob – not so comfortable.
Simple as that.
Offline Da67goatman
  • Burban
« Reply #3 on: December 08, 2011, 06:15:13 pm »
That's why we have 6 speeds. lol
<Pitcrew>
« Reply #4 on: December 08, 2011, 06:43:31 pm »
How about a MY6 4 speed overdrive.  OD final drive would be 2.25, really high...
Offline Senck243
« Reply #5 on: December 08, 2011, 07:54:17 pm »
Why not put a 5 speed in, and custom make a shifter...
1984 k10 305, sm465, np208
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #6 on: December 09, 2011, 11:34:48 pm »
Good answer!
Offline 1980c10
« Reply #7 on: December 10, 2011, 01:24:30 am »
Too much horsepower is kind of like having too much money. Never heard or seen it.  (btw those #'s aren't that big)
Even if you had a five speed you could use forth gear.
« Reply #8 on: December 10, 2011, 07:06:18 am »
     This is actually what I am doing with my 74 k10 I am rebuilding, I wanted overdrive and wanted to keep it simple.  Plus I thought it would be different to try a 4 speed overdrive, but it took me a while to find one for a 4wd.
     Like you I sometimes like to drive with my hand resting on the shifter.
Offline got2haul
« Reply #9 on: December 10, 2011, 01:51:38 pm »
Good answer!
I had car recently with a 6 speed manual.  I very much enjoy running a manual through the gears, but it was a close ratio and I was shifting all the time!  I learned to drive on a 4 speed - call it sentimental, if you will.
As far as the HP numbers - I guess I'm one of the unfortunate few that has never had a high-horsepower vehicle, so I have nothing to compare this engine to.  My primary goals with this swap are drivability and reliability.
Offline 1980c10
« Reply #10 on: December 10, 2011, 07:03:33 pm »
The ZZ4 will make the truck move pretty quickly when needed but will remain very drivable. My engine was dynoed at 393hp/432tq with a 5 speed and likes to embarass rice rockets, mustang owners and even the occasional bike. I like the 5 speed because I can take it down the interstate at little more than an idle and get 17-21 mpg no matter where I drive. You'd be hard pressed to break the sm465 and if you did they are about the cheapest transmission around. I have seen them on CL for arpound $50 several times and ended up giving mine away just to get it out of the garage.
« Reply #11 on: December 11, 2011, 07:56:23 am »
     And besides what 1980 said about availability, the SM 465 is one of the easiest transmissions I have cracked open.
