Author Topic: Carb/TBI Tank Difference  (Read 4602 times)
Offline redneckabbott
    • myspace
« on: December 09, 2011, 06:31:37 pm »
What's the difference in the carb gas tank and the TBI tank? My 87 needs tanks and my cousin is trying to give me one from his carb truck.
Currently Powerstroking it
Re: Carb/TBI Tank Difference
« Reply #1 on: December 10, 2011, 06:19:10 am »
     I believe the tanks should be the same, the sending units will be different.  Your 87 will need a fuel return line, while most carb trucks sending units do not have them.
     If you are changing tanks I would suggest new sending units also, cheap insurance unless you recently put in sending units.
    • myspace
« Reply #2 on: December 10, 2011, 11:08:30 pm »
Thanks! New sending unit will be going in.
Offline nucknoel89
  • Proud to be Canadian!
« Reply #3 on: December 11, 2011, 10:54:41 am »
The 87 tank has baffles to keep fuel at the fuel pump.  It's up to you whether you think it makes a difference.  I swapped a 5.3 (fuel injected) into my 81 with an 87 sending unit (for the pump) and I've been using the stock 81 tank.  As long as you don't run your tank too low you should be fine.
« Reply #4 on: December 12, 2011, 04:57:15 pm »
As stated, the difference is the baffles in the tank on the EFI versions.
