Author Topic: door gaskets/weather strip  (Read 6554 times)
Offline bowdown916
« on: December 09, 2011, 09:57:35 pm »
sup guys, just wondering if theres suppost to be a gasket around the inside door other then the one that goes around the cab. people keep telling me that it needs one,so not sure.. i have a 86 c10 scottsdale.
Re: door gaskets/weather strip
« Reply #1 on: December 10, 2011, 06:40:31 am »
     Are you talking about the rubber gasket that goes around the whole door frame on the cab once you open the door ?  If so, that is the only one I have ever seen, never heard of a second gasket there.
     http://store.73-87chevytrucks.com/merchant2/merchant.mvc?Screen=CTGY&Store_Code=7&Category_Code=WTHR  The complete kits are sold here, but as I said, I have only seen 1 gasket that goes in between the cab and door.
Offline bowdown916
« Reply #2 on: December 10, 2011, 10:39:23 am »
ummm,thats what i have now.. weatherstrip its on the cab... i guess theres only 1 gasket..  thanx bake
Offline Psycho71
« Reply #3 on: December 10, 2011, 12:25:30 pm »
 If I remember correctly, theres a second gasket/weatherstip on the pre-80's trucks. But 81 and later show only on the single piece.
« Last Edit: December 12, 2011, 04:55:54 pm by Captkaos »
Offline bowdown916
« Reply #4 on: December 10, 2011, 11:43:07 pm »
Ok. Me n my bro have the same year truck n he don't have that gasket on the door.. I shaved the door handle n put new gaskets for the door windows n when I open the door little bit of water gets in the seat .not sure why..
Sent from my DROIDX using Tapatalk
« Reply #5 on: December 11, 2011, 07:48:14 am »
     Does your truck have drip rails ?  If not water can collect on top between door and cab in the gasket area.  I have heard others complain of the same thing after removing the drip rails.
Offline bowdown916
« Reply #6 on: December 11, 2011, 10:58:40 am »
yea i remove the drip rails,but it only found little bit of water on the driver side..ill gotta see the older trucks early 80's ,maybe i can put gaskets around the door..
