Switching Leaf Springs
Topic: Switching Leaf Springs (Read 14966 times)
RegulatorInqInq
August 01, 2001, 07:28:00 pm »
I've got a 86' 1/2 ton longbox 4x4 with stock springs.I've also got a 77' 1/2 ton shortbox 4x4 that had a stock (I think) lift on it.Can I take the springs off of the 77 and put them on the 86?Will I have to change the position of the shackles?What is the proper way to measure the length of the springs?Any help would be appreciated because I pretty much know jack about springs.thanks.
high rider
springs
August 29, 2001, 09:18:00 pm »
yes they will fit. all 73 too 87 chevy truck parts are interchangeable.
Chvy350SS
Re: springs
September 21, 2001, 08:48:00 pm »
They will work. but you might have to move the shackles...depending if they are both 52" or 56", cause both were made..im not forsure what those would have, cause i know more about 2wd...but just measure them from the mounting holes..
