Author Topic: running lights wire location  (Read 8334 times)
Offline muddpuppy01
« on: December 11, 2011, 10:06:00 pm »
I am having a problem with my running lights. Meaning they don't work on the rear. Both left and right with the tag light. Brake lights work. I am looking to see if some one knows where the main junction is that connects the front lights to the rear lights.
Truck is a 83 k20 long bed
Re: running lights wire location
« Reply #1 on: December 11, 2011, 11:29:58 pm »
The rear running light circuit is spliced to the front running lights on the inside of the cab behind the fuse block at a bulkhead connector pin.
http://forum.73-87chevytrucks.com/smforum/index.php/topic,11766.0.html
Ckt 9 - The brown (running lights) wire generally runs the left framerail to a bulkhead plug dedicated to the rear lamps, then into the cab to the headlamp switch and then to the fuse block.  It often shares a multi-wire loom with one light green (back-up), one dark green (left turn/brake) & one yellow (right turn/brake) wires.
Have you already checked the bulbs and fuses?
Offline DnStClr
« Reply #2 on: December 17, 2011, 05:58:02 pm »
muddpuppy- I've sent you a pm (private message)
« Last Edit: December 21, 2011, 01:14:56 pm by DnStClr »
Don
87 Chevy Silverado
Offline muddpuppy01
« Reply #3 on: December 19, 2011, 04:44:02 pm »
update I ended up replacing the headlight switch to resolve my issue
« Reply #4 on: December 19, 2011, 08:06:54 pm »
Glad you figured it out.
