Author Topic: axles!  (Read 15620 times)
roger27
  • Guest
axles!
« on: October 20, 2001, 09:48:00 am »
the 1/2 ton axle is 3 inch, the 3/4 ton is 3 1/2, but that makes me wonder is a 1 ton axle 3 1/2 also? can i buy a 1 ton lowering kit for my 3/4 ton? thanks
Offline captkaoscustoms
Re: axles!
« Reply #1 on: October 24, 2001, 09:40:00 am »
For the rear, all you need is something to flip the axle over right?  Just get a 2.5" square tubing and cut a notch in it and weld it to the axle tube.  Make sure the drive angle is correct though.  Otherwise, I would say yes you can get a 1 ton lowering kit for it.  I would say call Belltech if you want a more "professional" opinion.
www.captkaoscustoms.com
Offline katkins750
Re: axles!
« Reply #2 on: October 27, 2001, 10:55:00 pm »
I have gotten all the lowering stuff for my C20 from AIM in AZ.  www.truckn.com.  Check the post in ref to "lowering 3/4ton".
Ken
