Author Topic: Dual steering stabilizer  (Read 27216 times)
Offline muddnutz
« on: December 16, 2011, 02:04:52 pm »
Any pics or suggestions on installing dual stabalizer?  Just bought one for my 86k-10 didn't come with instructions (pro comp)
Offline muddnutz
Re: Dual steering stabilizer
« Reply #1 on: December 16, 2011, 06:11:13 pm »
any body?
« Reply #2 on: December 17, 2011, 11:27:13 am »
      There are two basic types, stacked and side by side.  In either case, one end mounts on axle tube and the other end mounts to steering cross bar.
« Last Edit: December 17, 2011, 11:54:32 am by bake74 »
Offline heavychevy91
  • '86 Chevy K20
« Reply #3 on: December 17, 2011, 11:43:06 am »
I got mine from Rancho. They had instructions on the website. IIRC the part number was RS98501. http://www.gorancho.com/install_instructions.php It should be simalar for all installs
Offline 81GMCBILL
« Reply #4 on: January 05, 2012, 10:47:34 pm »
Hey Muddnutz, what makes you know that you need the dual stabilizer shocks ?
Just curious because I just rebuilt my front end and seems that it still likes to wonder a little
at around 40 to 60 mph.
Does this help with that problem ?
85 GMC K25 4X4 383/th400/np208
« Reply #5 on: January 06, 2012, 09:36:26 am »
     The recommend dual steering shocks for oversized tires.  They say it helps your steering componets from prematurly wearing out, and I always used them with bigger tires it seems to help on steering and keeping the trucks in a straight line.
« Reply #6 on: January 08, 2012, 04:39:29 am »
it helps when you hit pot holes or stumps it kind of reduces the shock to the steering wheel that you would feel when you hit something and the wheel being jerked out of you hand when you hit something
Offline Engineer
« Reply #7 on: January 08, 2012, 09:51:25 am »
I would think Pro-Comp would have directions on their website.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline johnhood
  • Rough Country Suspension
« Reply #8 on: January 11, 2012, 07:08:59 pm »
i installed mine on the front of the steering arm and adjusted by cranking the truck with them loose enough to slide
1985 Chevrolet Custom Deluxe 400 Small Block TH400/NP208  6inch Rough Country Lift
Offline mpeche923
« Reply #9 on: January 18, 2012, 11:05:16 am »
Hey there....    Here is a picture of my setup....  I can get better ones if need be
