Author Topic: 14 bolt disc brake?  (Read 8683 times)
Offline mean79
14 bolt disc brake?
« on: December 16, 2011, 05:25:47 pm »
Well im tearin down my 79 that i 3/4 swapped and never changed the shoes on the rear so noe.thay its pretty much the frame imma ditched those heavy drums for easier discs. I got the rotors and calipers but my question is can i use the disc brake brackets off the front axle to attach the caliper to the rear? I figured.it would also help stop the 44s and get it all straight for my 16 in Lift kit
Offline heavychevy91
  • '86 Chevy K20
Re: 14 bolt disc brake?
« Reply #1 on: December 17, 2011, 11:47:45 am »
In order to swap to discs in the rear you have to get swap brackets. the ones on your front axle will not work as their made into the dust sheild. You have a few options from aftermarket comanies. I like the ones from DIY4X. They have real high quality stuff for a great price. http://www.gorancho.com/install_instructions.php. You can use the same rotors that fit on the front of your truck and calipers can be used from a 1976-1978 Cadillac Eldorado rear calipers(emergency brake equipped.) or
1971-87 GM front 3/4 ton calipers.
Offline mean79
« Reply #2 on: December 17, 2011, 01:08:00 pm »
Thanks man wasnt quite sure could of swore i saw some where that somebody had done that
  • '86 Chevy K20
« Reply #3 on: December 17, 2011, 05:10:42 pm »
Im sure you could with a little effort. but its pretty hard to beat the $65 price tag  ;D
Offline mean79
« Reply #4 on: December 17, 2011, 05:21:14 pm »
True and no spacers and 3/8 steel
Offline Engineer
« Reply #5 on: December 18, 2011, 03:08:56 pm »
20 years ago when I swapped out my 14-bolt's drums for discs I used the rotors, backing plates, and calipers from the front of a 3/4-ton. Back then there was no Internet, and custom 4x4 fabricators were very local.
I had to drill/modify the backing plates, and have a machine shop build me a couple of spacers.
Things are much easier now with all of the laser cut parts available out there. But the two disc brake conversions I did back in the early 90s are still stopping the trucks I put them on. :)
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline mean79
« Reply #6 on: December 18, 2011, 06:53:35 pm »
How thick were your.spacers and did you torch/cut the dust shields off? Jw
