Author Topic: rad support  (Read 4792 times)
Offline necromonger
rad support
« on: December 19, 2011, 03:13:51 pm »
Hi everyone.
        Getting ready to tear down my 78 K30 here is what I need to know.The rad support is shot i would like to put a quad rad support in it's place is this possible also what else will I need to change.
new build,1978 chevy 3/4 ton 2 wheel drive 350 4 speed trans.
Re: rad support
« Reply #1 on: December 19, 2011, 10:42:00 pm »
Quad, as in stacked double lights?
On a 78 to do that you will need an 81/87 cowl panel, the plastic screen that goes under it, filler between the bumper,and the grill. Need 81/87 battery  tray, hood, inner, and outer fenders. You will also need hood springs, and hinges. You will need to cut the hinges into the cab's cowl. You will need to swap in the 81/87 and up wiper transmission assembly. Plus all the lights, the wire harness, and grill parts.
Offline 80stepsideguy
Re: rad support
« Reply #2 on: December 20, 2011, 03:03:13 am »
So in other words it can be done but it be cheaper to get a replacement radiator support.
thanks
pat
1998 Chevy 1500 S/B 2wd
Offline necromonger
Re: rad support
« Reply #3 on: December 20, 2011, 08:33:22 am »
I think I will look for a new 78 rad support I just hope I can find one.Thanks for the info.
Offline thirsty
    • Suitor's Garage
