Author Topic: GM 6.2 L Diesel  (Read 27916 times)
Offline junkman.
GM 6.2 L Diesel
« on: December 24, 2011, 11:07:58 pm »
What year did GM go to a one piece rear main seal on the 6.2 L and do they have small per-chamber heads (none turbo engines)
thanks JM
Offline Stewart G Griffin
Re: GM 6.2 L Diesel
« Reply #1 on: December 28, 2011, 09:26:52 pm »
i think 92 and later they went to 1-piece.
As far as the pre-chambers i don't know.
Re: GM 6.2 L Diesel
« Reply #2 on: December 30, 2011, 10:21:39 pm »
6.2L head have small pre chambers.
Offline Edahall
Re: GM 6.2 L Diesel
« Reply #3 on: December 31, 2011, 08:54:23 pm »
thanks JM
The precombustion chambers increased in size each year and horsepower increased.  The 1982 6.2's started off with 135 hp and they had the smallest precombustion chambers and by 1992, power was up in the 175 hp range.  Or course fuel economy took a big hit as the precombustion chambers got larger.
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
Offline junkman.
Re: GM 6.2 L Diesel
« Reply #4 on: January 03, 2012, 12:08:06 am »
hey guys thanks this is good info :)  the timing cover on my engine 1994 i think its a 6.2L
what parts were improved from 82-94 that made these engines better (non turbo)
Offline DnStClr
Re: GM 6.2 L Diesel
« Reply #5 on: January 06, 2012, 01:31:29 pm »
junkman, I was always under the impression that the 6.2 was last used in 1992. you should have a 6.5L in your 94
« Last Edit: January 06, 2012, 01:55:04 pm by DnStClr »
Don
87 Chevy Silverado
Offline Edahall
Re: GM 6.2 L Diesel
« Reply #6 on: January 06, 2012, 10:00:49 pm »
For the most part, they were cheapened.  The forged rockers were replaced with flimsy stamped rocker.  The earlier blocks had more chromium which slowed down cylinder wear and lessened the chance of the bottom end letting go.
-3.73 gears
-2" Lift
Offline bigchevyc30
  • the pig
Re: GM 6.2 L Diesel
« Reply #7 on: January 14, 2012, 10:01:56 am »
how many miles could i get out of a 83 6.2 k10 that has about 6 in of lift. im looking at one that someone has put 1ton axles underneith and idk the gearing for them can anyone give me a little info the truck im looking at the guys asking $3000 would that be good for this truck ps the lift is all suspension no lift blocks mostly if i get this it will be more for play and a little bit daily driver but would be good to know about what kind of mpg to be looking at from it
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
Offline 4x4x4x
  • 85k10 diesel
Re: GM 6.2 L Diesel
« Reply #8 on: January 15, 2012, 01:22:14 pm »
it's hard to answer your questions because of all of the variables. if the truck is in good shape then the price sounds good. mpg could be anywhere from 14 to 20+ depending on tires, gearing, condition of the fuel system, driving style etc. (we ave 18 to 22 with our 85k10 turbo with 411 gears on 33" 1250r15 goodyear mtr's) the good news is that parts are relatively cheep and available to rebuild any problems with the truck.
good luck
85 k10 swb, 6.5 diesel. banks sidewinder turbo, 700r4, auburn gear ected limited slip/lockers f & r, 411 gears, front slotted disks, rear disk brakes, 4"exhaust,  cibie headlight and fog lights, rancho rear spring lift, rancho shocks, new ft. springs,
Offline junkman.
Re: GM 6.2 L Diesel
« Reply #9 on: January 22, 2012, 01:59:58 am »
on the pass side of the block normally 6.2 or 6.5 is cast on mine is blank i think its a new GM crate engine it came out of a small buss and had a cracked piston this engine was being rebuilt while the truck was still being driven with the stock 82 engine in it
i found the invoice from the machine shop 4/4/2000 and i bought the truck in 10/2001 there is only 20,000 miles on it from the rebuild and i have not put over 150 miles on it in the last ten years its been parked
here's some part#'s
pistons SAF594--.050MM   rings E468K   gasket set 260 1315 O H    hope someone know what they are
thanks JM
