Author Topic: Cant find new 4x4 indicator switch  (Read 24951 times)
Online Mr Diesel
  • Aaron
Re: Cant find new 4x4 indicator switch
« Reply #15 on: January 12, 2012, 01:06:19 am »
That Autozone part does not look correct so I didn't want to special order it. I guess I could and return it if it didn't work, since they DO specify it for my truck.
EDIT: I suspect it is made by Echlin. It looks exactly like the Echlin part that NAPA used to stock. It was discontinued.
The original one I have has a long post which extends into the transfer case. That one above has a round ball bearing style end. It's possible the ball bearing contacts the spring inside and would work. The connector isn't the same either.
I contacted 4x4 Tech Inc today. They have the correct switch in stock for my truck, which I verified by their picture.  $170!  :o
They also have a retrofit switch. It is the same except the pigtail electrical connecter. About $140 with the new pigtail.
I sent an email today to BWD, asking if they would start making #S746 again.
« Last Edit: January 12, 2012, 01:09:03 am by Mr Diesel »
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
