Author Topic: help need stub axles/outer axel shaft ~spacer washer??  (Read 12881 times)
Offline frotosride
    • WFO CONCEPTS
« on: January 07, 2012, 12:26:00 am »
 :-[   READ LAST POST FIRST I NEED HELP AGAIN>>>So i bent the stub axle lobes on both left and right side. I don't need chromoly axles, yet. All i'm looking for as some stock replacements used or new for a fair price. I have found a few used ones but they do not have the the 3 lock ring grooves on the splines that i need. If anyone can help its for a corprate 10 bolt 8.5 or D44 more specific 1987 silverado v10. Thanks in advance.
« Last Edit: January 21, 2012, 06:43:11 pm by frotosride »
Re: help need stub axles/ outer axel shaft
« Reply #1 on: January 07, 2012, 01:11:29 am »
I put 40% stronger axles in my 86 3/4 ton with a 10 bolt last winter from Randy's Ring and Pinion. I did inners, outers, and 50% stronger axle joints. They were almost $100 cheaper than stock strength replacements. Thorugh Randy's.
When I called GM they said they are discontinued.
« Reply #2 on: January 07, 2012, 02:40:50 am »
dana 44s and 10 bolts are not the same thing. parts wont swap axle shafts are smaller on the 10 bolt
« Reply #3 on: January 07, 2012, 09:30:31 am »
Inners are different. Outer stubs will interchange though
« Reply #4 on: January 08, 2012, 03:07:16 am »
knew the inners where different didnt know the outers where the same. they do differ for what ton it is right?
Offline Engineer
« Reply #5 on: January 08, 2012, 09:46:36 am »
No, all outers are the same D44/Corporate, 1/2~3/4 ton all the same.......on GMs atleast. Frod, and Dogde IDK.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
« Reply #6 on: January 08, 2012, 05:45:13 pm »
thats cheap but good news
« Reply #7 on: January 08, 2012, 09:04:45 pm »
1 ton / Dana 60 outers are way bigger.
Offline frotosride
    • WFO CONCEPTS
« Reply #8 on: January 10, 2012, 12:54:02 pm »
Yes they do fiffer for the tonage mostely because the diffrent axles in the larger tons. D44 and corporate 10's are the only ones that have th interchangable outers but they are not all the same design so you still have to be careful when swapping them but most of the hub, knuckle and spindle part are the same like bearings, seals and ball joints.
« Reply #9 on: January 10, 2012, 07:17:39 pm »
There are two different legnth spindles. Not sure what year they changed but years ago I tried putting a spindle off an older 44 like early to mid 70s onto an 84 10 bolt. It was so long ago I don't even remember if it was to long or to short, but I do remember having to go back to my pile of axles in waste deep snow, and remove a second spindle!
Offline thirsty
    • Suitor's Garage
« Reply #10 on: January 10, 2012, 07:50:46 pm »
That's the Blazin we know!
Offline johnhood
  • Rough Country Suspension
« Reply #11 on: January 12, 2012, 01:06:54 am »
The Spindle Length Changed in 1977.  In 77-87 all the spindles are built the same 73-76 are all different..
learned that the hard way... you can use a pre 76 spindle just be sure to use the wheel bearings, hub, and rotors for it also .
Code: [Select]
They are different because GM used the dana 44 73-76 but that doesnt mean that theres not a later model with a dana 44 just be sure you get a 10 bolt spindle use your old one for measuring.
i put a dana 44 spindle with a 10 bolt hub and rotor and pulled them apart to change an axle shaft and realiazed when my bearings fell out on the floor somthing was wrong.
a junk yard will be your best bet or try a classic truck site that specializes in the older chevrolets
Goodluck,
John
« Last Edit: January 12, 2012, 01:13:04 am by johnhood »
1985 Chevrolet Custom Deluxe 400 Small Block TH400/NP208  6inch Rough Country Lift
Offline johnhood
« Reply #12 on: January 12, 2012, 01:15:00 am »
i believe the outers are different too because when i ran the 44 spindle my 10 bolt shaft had alot of play in it now that i put a 10 bolt spindle it doesnt anymore
« Last Edit: January 12, 2012, 01:18:09 am by johnhood »
« Reply #13 on: January 12, 2012, 05:48:46 am »
I have used 44 outers in 10 bolts with no problems. No difference in clearances that I could see.
« Reply #14 on: January 12, 2012, 07:22:05 am »
i had to cut a lock ring groove in mine to make it work
