Author Topic: Old red needs a head gasket  (Read 3340 times)
Offline sammy1759
« on: January 07, 2012, 12:28:28 pm »
Well today is the day I start the tear down on the 87 4.3L. I have never done a head gasket swap so I plan on taking the old camera to the garage to photo things so I know where they go when it's done. I have seen like 100 cat c12s be rebuilt and I always heard that it is just take off old stuff and put new parts on. I think it will be easier than I expect. Any helpful hints will be welcomed
~Sam
1987 c/r10 v6 with a turbo 400
Offline Jason S
Re: Old red needs a head gasket
« Reply #1 on: January 07, 2012, 04:49:48 pm »
If you don't have one already, a shop manual or something that has the head torque specifications and headbolt torque sequence. Keep the pushrods in order, don't break any bolts off, a 12 or 18 pack and a warm place. Clean all the old gasket material off, keep the gasket surfaces clean when reassembling and you should be good to go.
« Last Edit: January 07, 2012, 04:52:07 pm by Jason S »
« Reply #2 on: January 07, 2012, 06:55:41 pm »
     Like jasons said.  A manual, a place to keep everything in order, and taking your time.  Will keep you going in the right direction to be able to get it back together and running right.
Offline Engineer
« Reply #3 on: January 08, 2012, 08:40:18 am »
Use a thread tap to clean the threads in the block, wire wheel the head bolt threads clean and free of crud then reinstall with RTV on the head bolt threads.
Make sure to torque the head bolts before the RTV has a chance to set up.
Torque the head bolts in stages. I usually do 35 lb/ft then 65 lb/ft. After the final pull, allow the heads to set for 10~15mins then run the bolts again to final torque.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
