Interior & Equipment
Power Windows & Door Locks
Window Hesitation
Topic: Window Hesitation (Read 13862 times)
keg87
Window Hesitation
January 07, 2012, 07:39:50 pm »
Recently, my driver's side window started only going up and down part way. I wait a while and then it will go up some more, has this happened to anyone.
1982 Daily Driver
Re: Window Hesitation
January 07, 2012, 08:43:50 pm »
This has happened to me on both windows. I just took off the door panels and lubed the tracks and rollers at the bottom of the glass and sprayed all the pivot points with WD-40. This fixed the problem and the more often I work them the better they work. Hope this helps.
bake74
January 07, 2012, 09:24:34 pm »
1982 has the right answer to start, if that does not work, then you need to check the actual mechanism for binding or a bent spot.
74 k10, 77k10 Tom
bd
January 09, 2012, 12:15:26 am »
If you still have the problem
after doing all the above,
check the voltage and ground at the window motor while raising and lowering the window. You may have a window motor overheating from low voltage.
Window Hesitation
