Author Topic: 12 lift on LB  (Read 9733 times)
7946734
  • Guest
12 lift on LB
« on: July 26, 2002, 02:14:00 am »
how long are the drive lines
Offline 79GMC4x4
Re: 12 lift on LB
« Reply #1 on: August 07, 2002, 11:09:00 am »
I will have to tell you what the driveline shop will tell you.  Once you have the truck lifted, make sure it weighs approximately what it will when being driven regularly.  Then, measure from the center of the pinion yoke to the center of the rear output shaft yoke (to the center of where the U-joint trunion would be).  Do the same for the front, except you will measure to where the front CV joint meets up against the 'case.
'79 GMC shortbed 454 th400 14 bolt FF NP205 Dana 60
Offline 79GMC4x4
Re: 12 lift on LB
« Reply #2 on: August 07, 2002, 11:11:00 am »
Oh yeah, I dopn't know if oyu have the 2 piece driveshaft or not.  If so, get rid of the carrier bearing and have a one piece shaft built.
