Author Topic: what year is my truck (first timer)  (Read 9640 times)
Offline bgez64ss
« on: January 08, 2012, 11:12:31 am »
i have what i believe is a 79 or 80  the title says its a 82 ... its a short wide 2wd, with a 454,th400 with 12 bolt 308 posi. dual tanks, power windows and door locks, tilt colum, air cond, no cruize, and has the cab back molding....  but it has round head lights with the 79-80 big bezels... the cowl does not have provisions for hinges like the 81-87 and has the fabric head liner. and the dash pad is the old style also... it can not be an 82, im assuming it is a silverado.... the vin# is 2GCCC14D1C1119319 matching the title.  can anybody help me identify this truck before i tear it down..... would there be any numbers on the chassis that may help?   there is no tag on the firewall
Offline bgez64ss
Re: what year is my truck (first timer)
« Reply #1 on: January 08, 2012, 11:15:19 am »
and has hydro boost brake set up
« Reply #2 on: January 08, 2012, 11:28:16 am »
      From your vin# it is an 81.  Is the vin in the dash instead on on the door post.  I believe in 78/79 they switched to in the dash vin#'s.
     As far as the other parts you mentioned, someone could have switched most of them over from other trucks, a lot of parts will switch back and forth.
     Also welcome to the site from California.
Offline bgez64ss
« Reply #3 on: January 08, 2012, 11:32:08 am »
yes the vin is in the dash. the body dont seem to be molested, it actually has the original paint.  didnt the 81 have the hood hinges thru the cowl??  mine dont have the slots in the cowl where they would go
« Reply #4 on: January 08, 2012, 11:35:32 am »
     Is your front side markers horizontal or vertical ?
Offline Engineer
« Reply #5 on: January 08, 2012, 11:36:26 am »
Up to 1980 had 13 digit VINs. 1981+ have 17 digit VINs.
Look at your VIN tag on the dash. If it has a six sided flower shaped stainless steel pop rivet it us probably original. If the pop rivet is round or aluminum, or replaced by a screw, I would suspect it to have been changed.
Maybe this web site can help:
http://service.gm.com/dealerworld/vincards/
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline bgez64ss
« Reply #6 on: January 08, 2012, 11:43:39 am »
the dash pad covers the rivets... i am sure it has been changed, thats not my concern... would like to know what year it really is...  the marker lights are vertical
« Reply #7 on: January 08, 2012, 11:48:26 am »
     Verticle in 73 - 80 only.  Sounds like maybe the cab, or the whole truck has been swapped out or someone just took the vin# and put it on another truck.  Can you post any pics so we can see what you are talking about.
Offline bgez64ss
« Reply #8 on: January 08, 2012, 11:50:59 am »
 not that computer litterate, i will ask my daughter if she would post pics for me when she gets home...  thank you for your help
« Reply #9 on: January 08, 2012, 01:27:03 pm »
The hydroboost set up would lead me to think it was a diesel originally. Are the filler necks wide open, or do they have the flapper?
Sounds to me like someone swapped VIN#s for some reason or another. There is supposed to be VIN#s on the frame right under the drivers floor board but I have yet to find them on any frames I have sand blasted and painted.
« Reply #10 on: January 08, 2012, 08:13:29 pm »
     The 77 frame I just did had a partial vin # up where the steering box mounts on the inside of frame.
« Reply #11 on: January 09, 2012, 02:11:11 pm »
Frankenstein...Im curious why the VIN says 81, but title says 82...
Sounds like a 73-80 cab and interior.
Offline bgez64ss
« Reply #12 on: January 09, 2012, 05:32:37 pm »
the gas filler is not for a deisel.. but why the hydroboost brakes??  the whole truck to me seems like a 79 or 80 silverado except for the vin tag..... Mass needs a title on everything on the road
Offline bigchevyc30
  • the pig
« Reply #13 on: January 09, 2012, 06:25:14 pm »
the reason it would have hydro-boost is it has the heavy suspension package aka 1-ton my truck has that so that could help and for pictures go to photobucket and make a account and upload them there then get the IMG code copy paste it in the post
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
« Reply #14 on: January 09, 2012, 09:25:52 pm »
Short beds weren't available in 1 ton.
Only GMs I've seen with hydro boostthat were not 1 ton is diesel pickups, and full size wagons including gas jobs.
