Author Topic: 8 lug rim info  (Read 51105 times)
8 lug rim info
« on: January 11, 2012, 05:13:42 pm »
Jason S
If you are looking for wheels like the wheel vintique you posted, here are some of the trucks that had those type of wheels (not an all inclusive list):
1969-1987  Chevrolet & GMC 3/4 ton pickup trucks: C20, C2500, K20, K2500, R20, R2500
1973-1987  Chevrolet & GMC 1 ton pickup trucks with Single Rear Wheel (i.e., not dually or dual rear wheels): C30, C3500, K30, K3500, R30, R3500
1980-1993  Chevrolet & GMC G series Van: G30, G3500
1967-1996  Ford F-250 and F-350 (Single Rear Wheel) pickup trucks
1974-1995  Ford Econoline E-250 and E-350 Vans
1972-1993  Dodge D250 and D350 (Single Rear Wheel) pickup trucks
1971-1994  Dodge B-series Van: B350
Many versions of the 8-lug 6.5 inch diameter bolt pattern wheel could be had including: a 16 inch diameter wheel, a 16.5 inch diameter wheel, without split rims, with split rims, as well as several widths. Ford wheels would have a small (3/8 inch) Ford oval stamped into them and Dodge wheels had a small Chrysler Pentastar stamped into them. I'm sure there may be some exception, but they all should fit your C20 just fine. No differences in the 2 wheel drive and 4 wheel drive versions. Until recent years, most all the 8 lug trucks were lug nut centered wheels.
