Author Topic: fuel sending unit  (Read 5523 times)
Offline mrnda
fuel sending unit
« on: January 13, 2012, 01:12:19 pm »
am looking to buy a new fuel sending unit, truck is an 84 with one side tank.  looking at the parts store there are passenger side and driver side units listed.  is there a difference?
Re: fuel sending unit
« Reply #1 on: January 13, 2012, 01:19:05 pm »
Yes, I believe the difference is how the connections to the fuel line go.
Offline thirsty
    • Suitor's Garage
« Reply #2 on: January 14, 2012, 06:09:32 am »
The only difference is which way the connections point like zieg85 said. I've put the wrong one in once when I needed a tank because of a hole in the bottom and couldn't immediately get the right one. It worked fine. Just had to make a curve in the fuel lines.
« Reply #3 on: January 14, 2012, 07:00:37 am »
     You also need to know how many tubes are on yours, pickup tube, vent tube, and maybe return if yours has it.
Offline mrnda
« Reply #4 on: January 26, 2012, 11:17:57 am »
The prices for a 3 outlet are almost half the price of the 2, is there any way to make a 3 outlet work like a 2?  or should i just quit being
el-cheap-o?
Offline thirsty
    • Suitor's Garage
« Reply #5 on: January 26, 2012, 11:43:36 am »
Yes you can make it work.
On the truck which line isn't there? Return or Vent?
Offline mrnda
« Reply #6 on: January 26, 2012, 12:25:20 pm »
Do not know sir, when i pulled the existing unit was the first time i have ever touched one.
« Reply #7 on: January 26, 2012, 12:34:32 pm »
The 3rd hole is the tank vent, you would have to have a cap that vents.
