Wheels & Tires
5 lug to 6 lug conversion
Topic: 5 lug to 6 lug conversion (Read 13861 times)
Kolage
January 13, 2012, 06:35:21 pm »
what does it take to get 6 lug on my truck?
Re: 5 lug to 6 lug conversion
January 14, 2012, 05:52:50 am »
well 6 lugs where only on 1/2 4x4 till i think 99 then gm made all 1/2tons 6 lugs. dont think there’s a kit for it so if you want 6 lugs you can either get a 4x4 or get a 99+. BUT might be cheaper just to get new rims
bake74
January 14, 2012, 07:09:22 am »
What is your vehicle and year ?
74 k10, 77k10 Tom
Jason S
January 15, 2012, 10:18:34 pm »
Wow, a little over 15 years ago it seemed like the big rage was to convert the 6-lug Chevrolet trucks to 5-lug... What's next people wanting 16" tires?
For the rear, you should be able to swap in the 4x4 6-lug axle shafts and the 4x4 brake drums of correct diameter for the 5-lug shafts and drums.
On the front, there might be an aftermarket dealer for 6-lug hubs to fit the '73 - '87 1/2 ton pickups... I haven't seen anything like that yet.
DustyRusty
January 17, 2012, 05:13:28 pm »
Many of the '67 - '72 1/2 ton 4x2 Chevy/GMC trucks had stock 6-lug wheels. It's possible to go that route but you will be doing a lot of parts scrounging and it probably isn't worth it. You would have to find one w/ front disc brakes and associated parts. IDK if you could just swap rear axle shafts or whether you would need the whole rear axle ass'y. However, keep in mind '67 - '72 4x2 trucks had coil springs in the rear which means more modding, etc.
My $0.02
Rusty
1975 K-10 SWB Fleetside - 350/SM465/NP205/D44F 12-boltR, 3.73 gears. Original owner.
Customized by rust.
Wheels & Tires
