Author Topic: How to tell? 1 or 2 pc rear main seal?  (Read 57151 times)
Offline Senck243
« Reply #15 on: December 02, 2012, 05:22:59 pm »
It is definitely a two piece seal
Sent from heck
1984 k10 305, sm465, np208
Offline thirsty
    • Suitor's Garage
Re: How to tell? 1 or 2 pc rear main seal?
« Reply #16 on: December 02, 2012, 05:48:57 pm »
How did you determine that it is a two piece for sure?
« Reply #17 on: December 02, 2012, 08:13:50 pm »
There's some conflicting info here:
Small chevy 350 blocks will have a drivers side dipstick up to 1980. 1980 was when all of the small blocks went to passenger side dipstick. You will find one piece rear main seals were phased in in 1986. So it's true one piece rear main seal blocks will have a passenger side dipstick however so will two piece blocks so don't use that as a guide. You can tell by looking at the flexplate. If it's a counterweighted 350 it will be a one piece. The oil pans are different as well 55-79, 80-85, 86-99 and there are variances within those years too.
Offline thirsty
    • Suitor's Garage
« Reply #18 on: December 02, 2012, 08:18:58 pm »
Was I right on the size of the flange on the crankshaft or is that conflicting also Vile?
« Reply #19 on: December 02, 2012, 10:04:40 pm »
The two piece has a counterweight on the end of the crankshaft, the one piece does not and is a perfect circle.
Sent from my EVO using Tapatalk 2
