Author Topic: 1978 K10 355 restoration  (Read 63282 times)
Offline gcochran223
« on: January 15, 2012, 05:01:14 pm »
Doing some updates to the k10. 85' cab and bed swap,boat fuel tank,frame paint, vortec'd 80 350 in the works.pics to come!
« Last Edit: February 18, 2012, 04:28:53 pm by gcochran223 »
1986 k15, 355, th400 ,np205, Corporate 10 bolt,corporate 12 bolt, 8" suspension lift.4.56 yukon gears.
Offline gcochran223
Re: 1978 K10 hillbilly restoration
« Reply #1 on: January 15, 2012, 05:07:10 pm »
First pic is first day of having her.cap immediately off. Second pic is putting it to work getting the bugs out. Third pic is adding blocks front and rear. Bad idea. Went from driving like a cadillac to a hay wagon. Front blocks and rear blocks removed with leaf springs. Somewhere around a 4" lift.
Offline gcochran223
« Reply #2 on: January 15, 2012, 06:14:45 pm »
First pic is my lack of lug nut tightening on the wheel after the leaf spring adds. Second and third are random scrapping photos
Offline gcochran223
« Reply #3 on: January 15, 2012, 06:22:14 pm »
First pic is the th400 that I got that was from a 84 plow truck frame for $100.it was detonated,full rebuild with mods $700.I really wish i had a pic of where the th350 broke off the np203 from the previous owner not putting in the support arm. This is the time I swapped out my th350 and np203 for the th400 and np205 out of a 84 plow truck.transfer needs adjusted still kind of a pain to get from 4lo to 2wd.warn hubs installed in the front.Second pic is pre 35x12.50x15 with the 31s.third is the discover stt. Fourth is noticing I really had a issue with my cab being rotted.
« Last Edit: January 16, 2012, 04:48:05 am by gcochran223 »
Offline gcochran223
« Reply #4 on: January 15, 2012, 06:46:11 pm »
First pic is cab roller. Second/third is the 85 c30 donor cab
Offline gcochran223
« Reply #5 on: January 15, 2012, 07:32:52 pm »
Finally in the shop waiting its turn.
Offline gcochran223
« Reply #6 on: January 15, 2012, 07:44:51 pm »
Just seen its not in the build section if someone could move it please.
« Reply #7 on: January 15, 2012, 08:25:48 pm »
      They will move it when they see it.  First question, why do you call it hillbilly build ?  Looks like you are taking care to do a good job.
      Second.  So glad to hear that you removed the front blocks, very dangerous and illegal almost everywhere.
     Third, nice pics, love to see progress, keep them coming.  And finally, can not wait to see what it transforms into.
Offline gcochran223
« Reply #8 on: January 15, 2012, 09:17:37 pm »
First picture is the dismantling of the truck after a year in waiting.rest of pics are just of removal of parts. Everything went good no major issues. Did not expect the fenders to ne held on with as many bolts as there were. Front ones going onto the radiator support , 4 I believe were a pain.
Offline gcochran223
« Reply #9 on: January 15, 2012, 09:23:20 pm »
Thanks for the support. Hillbilly restoration not rigging up or other sorts but more of it will look like when its finished.lift blocks were the worst thing I did.I don't recommend it to anyone , it was the 35 dollar lift at the time, that was Hillbilly there.got a lot of the little odds off the front.hoping to get the engine in the stand and bed off next week and get down to frame.
Offline Jason S
« Reply #10 on: January 15, 2012, 09:28:45 pm »
Lots of bolts for the front sheetmetal.
It looks like things are progressing well after the year long hiatus. Are you going back with the orange?
Keep the photos coming.
Offline gcochran223
« Reply #11 on: January 15, 2012, 09:45:33 pm »
It was actually some type of red. I pulled out the front bench and was amazed to see the factory paint compared to the sun fade now. I ran the dash codes but can't remember what they called it. Here is the paint scheme I'm going with, I love these old chevys in the 2 tone green and reds and other misc. But some type off hugger or chevy orange as a main with a white as two tone.I found a pic online but it won't let jpeg download, so I need to figure out change it.
« Last Edit: January 15, 2012, 09:47:28 pm by gcochran223 »
Offline mikek20
« Reply #12 on: January 16, 2012, 03:31:37 pm »
Im glad the blocks came out. Looks like your moving along pretty well. I support the two tone idea, its the perfect candidate for it.
Offline gcochran223
« Reply #13 on: January 28, 2012, 11:14:32 pm »
Started back dismantling the cab and bed off the body
Offline gcochran223
« Reply #14 on: January 28, 2012, 11:16:47 pm »
More pics of the evening
