Author Topic: steering column  (Read 6515 times)
Offline burkitk
steering column
« on: January 22, 2012, 05:34:53 pm »
could anyone tell me if a steering column out of a 90 blazer will fit a 87 pickup?
Offline 87454westernhauler
Re: steering column
« Reply #1 on: January 22, 2012, 05:48:20 pm »
if it is a full size K5 blazer yes it should work. but if it is an s10 series it wont work.
79 gmc c20 350 th350
78 k1500 4x4 350 th350
Offline burkitk
Re: steering column
« Reply #2 on: January 22, 2012, 05:55:51 pm »
thanks.  it is a full size.  i thought it looked the same didnt know if something was different where it mounts
Re: steering column
« Reply #3 on: January 22, 2012, 06:34:10 pm »
Same from 73-87 as far as mounting.
Re: steering column
« Reply #4 on: January 22, 2012, 08:59:01 pm »
As far as mounting yes, but the pin position in the plugs might be off.
Offline gto109
Re: steering column
« Reply #5 on: January 22, 2012, 09:27:32 pm »
let us know if the pins are right i just got one out of a 90 suburban for my 85 but i can't put it in for a little bit.
85 Scottsdale k-10 305 700r4,
86 Trans Am 305 350th
06 Dodge Ram daily driver
Re: steering column
« Reply #6 on: January 23, 2012, 10:52:30 am »
83-87 should be the same, and depending on the donor, you should be able to just swap out the switch.
Offline burkitk
Re: steering column
« Reply #7 on: January 25, 2012, 09:58:15 pm »
thanks for the help.  It bolted right up the only plug i had to change was the backup light
