Author Topic: timing tbi motor  (Read 3794 times)
Offline mpullen66
timing tbi motor
« on: January 24, 2012, 11:20:00 am »
How do I set the timing on an 1987 chevy half ton 2wd. 350/5.7 motor. I read on another forum of disconnecting a browm wire, setting the timing to zero, and plugging the wire back in and let the computer take over.
. Is that correct?
Is there any way to advance the timing or doin some "TEST AND TUNING"?
thanks for any advice,
Mike
Mike
1987 LWB,2WD,350,700R4  times 2
Re: timing tbi motor
« Reply #1 on: January 24, 2012, 01:46:58 pm »
The computer controls the timing on the TBI motors, so they only way to change the advance is to put in a chip or program one.  There is no way to "play" with the timing.
Offline mpullen66
« Reply #2 on: January 24, 2012, 02:46:35 pm »
So do I set it to zero like I read?
Mike
« Reply #3 on: January 24, 2012, 03:46:09 pm »
Yes, unplug the wiring in the harness and set the timing to 0 degrees, you could move it some, but not much as it could cause pinging.  If the motor is stock, I would set it to 0.
Offline mpullen66
« Reply #4 on: January 24, 2012, 07:04:28 pm »
Thank You!
Mike
