Author Topic: whats a good manual trans?????????  (Read 35517 times)
Offline 1983stepside
« on: January 29, 2012, 02:57:23 pm »
I'm building a 1983 Chevy c-10 2WD, stepside, and it had a 3 speed in it with a 250 i-6, i took all that out and am using a 350 horse 350 v-8, and I'm looking for a good 4 speed, or 5 or 6, for that matter, that i don't have to re build the floor to get trans to fit, or anthing like that, and also doesn't have to be but id like to use a hydraulic clutch, but not a must have, any ideas, tips, links, and pics would be awesome the truck will have 3:73, in rear end, and its going to be on air bags, not laying frame, it ll just be as low as i can get it, with out cutting the body, or bed floor, so anything any one could give as far as the trans and a good one to use, thank you in advanced
Re: whats a good manual trans?????????
« Reply #1 on: January 29, 2012, 03:28:52 pm »
With a 3.73 you can go with a Muncie 4 speed M21 and have a ball.  It is a direct replacement for the original 3 speed in it.  Drive shaft length and yoke will fit great.  The M20 will give you a slightly lower first gear.  Those are the easiest to go with.  Finding a MY6 A833 new process 4 speed overdrive is also a direct replacement but harder to find.
Offline yellowk20
  • Truck Poor
« Reply #2 on: January 29, 2012, 03:53:15 pm »
A T-5 5speed from a later model C1500 would be an ok swap.   as would a NV3500 or NV3550
"If you're Gonna be stupid you better be tough"
« Reply #3 on: January 29, 2012, 04:29:54 pm »
thanks zieg85 for the info, i actually have an a883 new process or at least i think that's what it is, i bought a while ago, but i was told that there not good for what i have, and they cant really handle an occasion beating as well as as a muncie, so that's why i was looking for something different, have you heard any different? i know it ll make me get better mpg, but I'm not to worried about that since the truck wont be a dd, i don't know maybe if you have any more info on the new process i might just use that thanks again
« Last Edit: January 30, 2012, 10:34:36 pm by Captkaos »
« Reply #4 on: January 29, 2012, 04:38:55 pm »
The A-833 is a great transmission IMO but I have never beat on one.  The non- OD Mopar version go behind Hemi's.  Some say because overdrive is in the place of 3rd gear, it makes them weaker.  I have 3 of them on a shelf so I am certainly gonna try one out in my project truck which is a 1986 C10, originally a 3 on the tree with a 4.3L.  The 5.7L engine that is going in there ran like a scalded dog that came from a 1986 Suburban, hoping to have a decent toy to play with.
« Reply #5 on: January 29, 2012, 05:03:07 pm »
ya i read an artice that custom classic truck mag had, about the new process, and how they were used, in mopar, Ive never heard of this trans until a year or so ago when i figured out what i had, so i have no idea how it ll handle, i don't plan on beating on it on a daily basis, but my truck is a toy when i get it done, and there meant to have fun with lol, ill deff look into it more and the muncie, if i did go the muncie route, would here be any thing needed to be changed as far as trans tunnel, pedals, etc..... thanks again, id post a link to that article i read but i don't know how to do that
« Reply #6 on: January 29, 2012, 05:20:39 pm »
They are almost identical in size, you shouldn't need to do a thing.  The only issue you may run into with the Muncie is the speedometer cable routing as they made two different tailshafts that the cable comes out the drivers side or you will need an extension as some come out of the passenger side.  You will also have to pay close attention to the shifter you choose to come out in the factory spot to clear the bench seat.
« Reply #7 on: January 30, 2012, 10:36:10 pm »
I pulled a 3 on the tree out of mine and put a M22 in its place.  I didn't change anything but the shifter to the floor.
« Reply #8 on: January 30, 2012, 10:39:51 pm »
I thought the M22 had the fine splines only...
« Reply #9 on: January 30, 2012, 10:59:34 pm »
You asking about the clutch side or the output side.  I always replace the clutch if I am changing transmissions, and on the output I just put a 32 spline yoke on it.
Offline Skunksmash
« Reply #10 on: February 01, 2012, 10:12:58 pm »
Get one of those t-56's out of some wrecked camaro or trans-am from the junkyard. Way better than a lot of those old junkers that came in some of the older stuff.
« Reply #11 on: February 06, 2012, 05:03:15 pm »
T-56's require a special flywheel and definitely a new clutch assem, they operate completely different.
Offline Elpresidente
« Reply #12 on: February 06, 2012, 06:43:42 pm »
WAIT! Maybe I read this wrong, but an A833? The kind with the 3 speed + overdrive? That fits on a SBC?
My dads got 3 in my garage, guess I found a use for one of them!
'82 Chev Scottsdale
Proud to be Canadian \m/
« Reply #13 on: February 06, 2012, 08:13:26 pm »
Google New Process A-833 and look.  There was a GM version and the RPO code for it was MY6.  It came in both 2 wheel and 4 wheel drive versions.  Came in 1/2 tons only, behind diesels and the 5.0L.  I don't know if it was available in 1987 behind the 5.7 TBI or not.
