Author Topic: Will '01 Chevy Wheels fit my '87?  (Read 5922 times)
Offline SiveradoScott
« on: January 29, 2012, 05:11:15 pm »
Will wheels off a 2001 Chevy Truck work on the 87 1/2 Ton Chevy 4x4?  They are the same bolt pattern but I'm unsure whether the back spacing is different.
Thanks
Re: Will '01 Chevy Wheels fit my '87?
« Reply #1 on: January 30, 2012, 05:42:35 am »
     You did not give the model of the 2001, on the back side of the rim (both sets of rims) should be the backspacing stamped into the rim.  You will probably have to clean it up in order to see it.
     Here is a great article on measuring bolt patterns, back spacing, and offset.       https://www.rsracing.com/tech-wheel.html
Offline Edahall
« Reply #2 on: February 01, 2012, 10:43:52 am »
It'll fit but most likely, the backspacing will be incorrect and look funny.
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
« Reply #3 on: February 01, 2012, 11:01:36 am »
http://forum.73-87chevytrucks.com/smforum/index.php/topic,21735.msg179664.html#msg179664
granted they are 3/4 but i think the back spacing should be the same
