Author Topic: Heat/cold/defrost mechanism lubrication  (Read 5294 times)
Offline 81GMCBILL
« on: January 30, 2012, 11:16:11 pm »
Anybody have a secret on whats the best spray lubrication to use on the plastic
moving parts that run the cables to the heater core box ?
85 GMC K25 4X4 383/th400/np208
Offline PromiseKeeper
Re: Heat/cold/defrost mechanism lubrication
« Reply #1 on: January 31, 2012, 08:05:17 am »
If they are are working hard, it's my guess that the controls aren't the major problem. I would guess that the real problem lies in the cables. That said, I'd try some silicone spray on the plastic. You may need to take the cables off and lube them. Not a bad job if you don't have A/C. Disconnect the cable at the control and you'll be able to tell where the problem is.
Offline 81GMCBILL
« Reply #2 on: January 31, 2012, 09:40:04 pm »
hey thanx "promisekeeper" - the silicone did the trick - works like new- !
