Author Topic: 2:73 to 3:42 swap  (Read 3987 times)
Offline Mike R
2:73 to 3:42 swap
« on: February 17, 2012, 07:35:46 pm »
I have a 1987, 2 wheel drive with a 305 tbi. Thinking about swapping the 2:73 rear end gears for  3:42s, as I hate the way my engine lugs causing the 700r4 to shift in and out of overdrive.
Will I need to reprogram my computer for the new rear end gears?
Any issues to consider other than changing the speedometer gears?
Re: 2:73 to 3:42 swap
« Reply #1 on: February 17, 2012, 08:30:57 pm »
That won't bother the computer at all. As you said the spedo will be off unless you swap out the gear in the tail shaft.
« Reply #2 on: February 18, 2012, 06:52:41 am »
     Mike R welcome to the site from Ca.  Blazin is right on, just change out the speedo gear and all will be fine.
Online bd
« Reply #3 on: February 20, 2012, 12:29:19 am »
Going to 3.42 may not resolve all of your nuisance downshifting.  700's are known for dropping out of O/D at around half throttle.  You'll probably need to upgrade to the Corvette 3-4 throttle valve sleeve, as well.  http://www.summitracing.com/search/?keyword=bmm-70237&dds=1
« Last Edit: February 20, 2012, 12:31:11 am by bd »
Offline Mike R
« Reply #4 on: February 20, 2012, 07:49:25 pm »
Thanks to everyone for your information. As an update I took my truck to a local transmission shop the other day and the owner told me most of what I thought was shifting is in fact the torque converter locking up in both 3rd and 4th gear, possibly caused by a bad pressure switch, tps or map sensor.
I'll need to leave the truck with him for about a week before he can get to it.
I changed the tps just for the heck of it but the problem still exists, is there anything I can do myself to diagnose the problem?
Offline mattgood
« Reply #5 on: February 20, 2012, 08:06:14 pm »
    Never seen that product before.... seems like a good idea though.
Don't let your water melon.
