Author Topic: Drum Brakes Question!  (Read 5047 times)
Offline AJII
« on: February 20, 2012, 07:50:38 am »
Hey Guys,
Rebuilding the rear brakes on my K10 and have a few questions.
I keep reading about some "wavy washers" that should be there? But I have taken mine apart, and do not see anything of the sort. Possible they have been lost over the years, or do some set ups just not have them? Anyone have a picture of what they should look like?
Also, what are these and where do they go? My spring set came with four of them, but again, I do not see any of these on my truck. Help?
Re: Drum Brakes Question!
« Reply #1 on: February 20, 2012, 09:22:05 am »
     When you buy rebuild kits they come to fit several different models.  If yours did not have those when you pulled them off they are not soppose to be there.  That is unless someone took them off in whice case I would think your brakes would not be working.
« Reply #2 on: February 20, 2012, 09:37:13 am »
"Wavey washers" have ~5/16" ID.  They're an anti-rattle spring.  When used, they fit over the pivot pin at the top of the park brake lever arm, between the lever arm and the rear brake shoe.  The lever arm 'pin' is inserted from the back side of the shoe through a round mounting hole in the shoe and retained with either an "E-clip" or a "horseshoe clip."  However, there is a second design park brake arm that mounts with a slot-and-tab design, that doesn't use the pin and 'wavey washer.'  The primary difference between the two is in the pivot.
The image you posted is an adjusting slot hole plug that is used for brake designs with the adjusting slot in the backing plate.  Most of the later GM adjusting slots were in the drum.
Offline AJII
« Reply #3 on: February 20, 2012, 01:30:18 pm »
Thanks alot for that reply! Put it all back together as it came off and all is well.
Just never know when working with something this old if something is supposed to be there, but isn't!
