Author Topic: Best way to repaint 8" Ralley wheels  (Read 6310 times)
Offline 86swb
  • Born a Chevy man
« on: February 21, 2012, 02:16:37 pm »
I need to repaint the 8" Ralley wheels on the truck I just got from my Father-In-Law and what is the best way to do this without getting spray paint on the tires?
'86 swb Siverado
'84 lwb Silverado (low miles)
1931 Model A 2-Door Sedan
  (in family since new)
I just gave the '31 to my Grandson
Offline thirsty
    • Suitor's Garage
Re: Best way to repaint 8" Ralley wheels
« Reply #1 on: February 21, 2012, 02:52:57 pm »
Put painters tape around the bead on the tire, cut paper or plastic to fit, tape the paper or plastic to the painters tape that is around the bead.
Where I used to work I used to sand blast and paint the wheels of our company trucks. I used to leave the tires on the wheels when I blasted them, then masked them off before paint. They were propane delivery trucks with white wheels. I used to use rustoleum thinned with mineral spirits sprayed out of a gun. Took a long time to cure but held up surprisingly well.
Offline 87454westernhauler
« Reply #2 on: February 21, 2012, 04:42:55 pm »
i usually take a wire wheel on an angle grinder and try to get as much of the old paint and rust off, mask the tires and valve stems off  and then put 2-3 coats of automotive primer on them and then 1-2 coats of finish paint out of a rattle can on mine. i usually use rustoleum!
79 gmc c20 350 th350
78 k1500 4x4 350 th350
« Reply #3 on: February 21, 2012, 06:26:31 pm »
     Prep work is key here especially with wheels, if you do not take your time the paint will not last very long.
Offline 86swb
  • Born a Chevy man
« Reply #4 on: February 22, 2012, 09:05:19 am »
Thanks. I use to have a metal band that went around the wheels and you had a clip that you could use to adjust it but I lent it to someone and never got it back and not sure who that was.  :-\ I hate browing(sp) things and sometimes this is what happens when you lone things out. I bought it at Eastwood but all they now have is paper. I guess I will just have to do it the old fasion way. Oh yes, I believe in doing prep work and doing it right. You can really mess up a good paint job if you do not. Thanks
'86 swb Siverado
