Author Topic: Will an 82 lwb fit on a uhal tow dolly?  (Read 15672 times)
Offline 454Man
  • Why Race?
« on: February 23, 2012, 08:28:39 am »
Or can someone please measure the distance from the center of one wheel to another.
Re: Will an 82 lwb fit on a uhal tow dolly?
« Reply #1 on: February 23, 2012, 10:21:06 am »
69" in the front.
Offline 454Man
  • Why Race?
« Reply #2 on: February 23, 2012, 11:02:14 am »
Ok thanks
Offline gto109
« Reply #3 on: February 23, 2012, 07:06:08 pm »
I used a tow dolly to pull mine 7 miles once last year.  I rent them from an equiptment rental place in town becouse u-haul here almost never has one.
85 Scottsdale k-10 305 700r4,
86 Trans Am 305 350th
06 Dodge Ram daily driver
Offline 454Man
  • Why Race?
« Reply #4 on: February 23, 2012, 07:39:35 pm »
Folks at uhal told me they couldn't rent me one after I told them what I was towing. They put it in the system and it told them the truck was too wide??? Idk. I'm thinkin of just usin to straps and having someone drive the uhal truck while I drive the lwb
« Last Edit: February 23, 2012, 07:41:14 pm by 454Man »
Offline HAULIN IT
« Reply #5 on: February 23, 2012, 10:54:46 pm »
How far are you going? Is it really worth taking the chance messing up your truck, or worse...the back of the U-haul? If your renting a U-haul anyway to pull it, why not just pay a towing company to move it for you?
Just a thought, Lorne
Offline gto109
« Reply #6 on: February 23, 2012, 11:03:11 pm »
Around here I do not think it is legal to us a tow strap or chain.  It is really not worth it to use them in my opinion.
Offline 454Man
  • Why Race?
Re: Re: Will an 82 lwb fit on a uhal tow dolly?
« Reply #7 on: February 23, 2012, 11:26:51 pm »
Its about 30 miles which equals close to 200 in towing from a towing comp. Its 75+ .59 cents a mile. So tryin to be cheap I figured heck ill just tow strap. Budget is under 3k this is a run down so far...truck 700, engine 700, trans 450,( water pump, starter, fuel pump, 200) hope I can use an old 76 800 cfm buick carb I have, but I only will now when I hook it up may be too much idk. Hope the flywheel is good, torque converter cheapo from orielly 130, motor and trans mounts 40idk, oil(break in and after 60) trans fluid 50, manifold gasket. Cam 150 later on valve springs idk. See where this is going
Offline 454Man
  • Why Race?
« Reply #8 on: February 23, 2012, 11:47:29 pm »
Oh edelbrok intake to go with the cam. 160 idk
Offline 454Man
  • Why Race?
« Reply #9 on: February 24, 2012, 10:19:13 am »
I'm gonna just get the tow dolly. I messured the dolly and it was 68 inches wide. Hope the tires fit the width of the tow dolly.
Then I can get it home and see if I can get the engine to unlock and run. Its a long shot, but long as the block and heads aren't cracked it could be ca core for another 350
« Last Edit: February 24, 2012, 10:21:47 am by 454Man »
« Reply #10 on: February 25, 2012, 12:51:46 am »
Where are you going to lose that inch?
Offline 454Man
  • Why Race?
« Reply #11 on: February 25, 2012, 01:29:40 am »
To all that are ever thinkin about usin a uhal tow dolly to tow this truck... it ain't happnen. Its 3 or 4 inches too wide on each side. Check out my new thread
Offline fitz
« Reply #12 on: February 25, 2012, 05:06:32 am »
Keep in mind that in some states like in Mass the vehicle on the tow dolly must be registered and insured.
« Last Edit: February 25, 2012, 05:42:43 am by fitz »
Offline 454Man
  • Why Race?
« Reply #13 on: February 25, 2012, 05:33:02 am »
Keep in mind that in some stares like in Mass the vehicle on the tow dolly must be registered and insured.
Got the truck at my house. Had it towed by a tow comp
