Crew Cabs
91 crew cab speedometer wires
Topic: 91 crew cab speedometer wires (Read 10823 times)
flight71
New Users
March 03, 2012, 08:42:35 am »
I was wondering if anybody had one and could tell me what color wires are that plug into the speed sensor on the gear drive transfer case? Thanks for any help
bake74
Re: 91 crew cab speedometer wires
March 05, 2012, 05:12:57 am »
If you do not get an answer here, you might check over in the suburban section to see if you can find the answer there.
74 k10, 77k10 Tom
ehjorten
March 05, 2012, 09:16:14 am »
I've got one and can tell you! I can look at it when I get home. I also have the factory wiring manuals so I can give you a diagram if you need.
What seems to be the trouble?
-Erik-
ehjorten
March 06, 2012, 10:27:34 am »
Forgot to do this last night.
Tying a string around my finger now!
-Erik-
ehjorten
March 09, 2012, 09:20:06 am »
The VSS should have 2 wires...
PIN A: 0.8 mm˛ (18 ga) PPL/WHT
PIN B: 0.8 mm˛ (18 ga) LT GN/BLK
-Erik-
Crew Cabs
