Author Topic: lifted truck gears  (Read 12176 times)
Offline bigchevyc30
  • the pig
lifted truck gears
« on: March 03, 2012, 09:43:27 pm »
ok im looking at a 83 k-30 with about a 6 inch lift on what appears to be 34 inch tires (not sure didnt really look at them) but the fron spider gears are out in the front and it had 3.73 gears. my question is would it be best to lower the gears to 4.11 or to leave them as is if i get the truck as i would like to play with it but still be able to handle driving on the road with out blowing up the tranny. if anyone could help me thanks
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
Re: lifted truck gears
« Reply #1 on: March 04, 2012, 05:28:43 am »
depends on the trans but 3.73 would be ok for only 34s i would even think they would work well with 38s
Offline bigchevyc30
  • the pig
« Reply #2 on: March 04, 2012, 02:28:40 pm »
its got a turbo 400 im thinking the truck is a good deal as the guy wants 1500 for it and it only needs the spider gears in the front heres a picture i took with my phone of it
Offline 454Man
  • Why Race?
« Reply #3 on: March 04, 2012, 04:23:18 pm »
That's a great deal. Nice truck
Offline bigchevyc30
  • the pig
« Reply #4 on: March 04, 2012, 04:26:05 pm »
also another question would it be best to just get the spider gears or to put a power-lock locker in it cause it has a full float axle for the front axle
« Reply #5 on: March 05, 2012, 05:17:41 am »
     The answer depends on how you are going to use the truck.  Lockers are great if you plan on 4 wheeling a lot or use it a ton in the snow.  Other wise lockers are expensive to put in and do bring the gas mileage down a lot unless it is a selectable locker.
Offline heavychevy91
  • '86 Chevy K20
« Reply #6 on: March 05, 2012, 07:54:32 am »
Judging by the pic it has 37" Wrangler H1 take offs. 3.73's would be pushing it. You would be happier with 4.11's or even 4.56's.
http://www.offroaders.com/tech/gear-ratio-chart.htm
« Reply #7 on: March 05, 2012, 10:05:16 am »
they do make 34" take offs or something close to that
Offline thirsty
    • Suitor's Garage
« Reply #8 on: March 05, 2012, 10:06:43 am »
Did you drive the truck? That would be the best deciding factor for you. I would think that 3:73 will do fine. Also I would be willing to bet that the front end needs more than just spider gears.
Offline bigchevyc30
  • the pig
« Reply #9 on: March 05, 2012, 12:43:51 pm »
ok the truck has bigger tires than i thought they are 37's so then by what ive sen from here if i do get the truck i wouold be loking at putting 4.88 gears on it thanks everyone for all the helpful knowledge
« Last Edit: March 05, 2012, 05:12:39 pm by bigchevyc30 »
« Reply #10 on: March 06, 2012, 12:36:41 am »
4.88? 4.10s are the highest i would think of going with only 37s. if i was to do mine over i would go with 3.73 not 4.10s but its not cost effective to replace them now. you will be screaming just going 50 with 4.88
« Reply #11 on: March 06, 2012, 06:23:41 am »
      I had 4:88 in a jeep I built once for rock crawling, I trailered it everywhere because the top speed was 60 mph on the freeway, unless you wanted to blow it up.  (which my ex-wife did after we got divorced)
Offline snibook7537
  • Vince Ziolkowski
« Reply #12 on: March 06, 2012, 12:35:01 pm »
if it drives nice I would still pull the trigger on that truck for the price, even if you had to go out and find a whole new dana 60 that trucks awesome.
1984 Fiero se pwr windows Holley TBi, cam, 86 5spd
1987 GMC V3500 350 TBi 4spd 205 t-case
Shoulda never sold:
1976 c-10 beater 250-6 4spd no pwr steering, brakes. Recycling truck
